BMW M3 Forum (E90 E92)
Mporium BMW
      10-27-2008, 04:19 AM   #1
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
How's the ride/handling on the H&R's?
Guys, how has the ride/handling changed since you install your H&R Sport Springs? Do you guys notice the rebound a bit dead? Or does it still feel like the suspension is working in optimal condition like stock?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      10-27-2008, 01:09 PM   #2
Speedtrap
United Kingdom
57
Drives: A very fast car :)
Installed H & R Sports (there is a race version as well) - With my EDC off, I feel that there is less roll, and less rebound. Wiith EDC, its fantastic and the ride is firmer/harder. Always love H & Rs
      10-27-2008, 05:00 PM   #3
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
Improved handling.. hmm I'm just afraid the handling might be worse
      10-27-2008, 05:02 PM   #4
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
the car will be jumpy like a motherfucker. i was watching how longtran's car was bouncing in front of me on the freeway the other day. reminded me of the crappy H&R springs i had on my 335
never again
      10-27-2008, 05:20 PM   #5
MVEED3
Drives: '16 GT4
Car feels closest to factory ride than on other cars that I've installed only lowering springs. The car retains it's handling with the added benefit of decreased roll as Speedtrap stated since the springs follow the linear design of the stock pieces. I was actually surprised H&R didn't use a more increased rate. The pros are prolonged shock life and ride comfort but at a cost of ground clearance under compression. The felt covered pieces under the front bumper are getting frayed from scraping. I don't have problems with bouncing and it even smoothed out that pogo effect I had on deep compressions.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick
2016 Agate Grey GT4 PCCB LWB
2013 HP4 Competition
      10-27-2008, 05:30 PM   #6
camaross305
camaross305's Avatar
135
Drives: 2008 M3
ive seen both the eibach's and h and r's and the eibach's are def. a bit smoother. My friend just installed the eibach's and his ride is exactly like factory only less roll and slightly lower.
      10-27-2008, 05:35 PM   #7
MVEED3
Drives: '16 GT4
The thing I don't like about the Eibach springs is that one side is progressive. I can't remember if it's the front or back.
I'm sure there are a good amount of folks with both setups in your area. Just set up a drive so you can feel them for yourself.
Allen
      10-27-2008, 05:50 PM   #8
longtran
longtran's Avatar
1433
Drives: E90 M3
2006 325i  [0.00]
never again
it wasnt bouncing. you crazy man. its stiff than a mofo when you have edc on. its solid with the springs. i'd stay away from the h&r race springs though.
      10-27-2008, 06:08 PM   #9
ModBargains.com
Drives: JB E92 335i
I've heard great things about H&R springs on the new M3s. I would highly recommend it. If you want to go above and beyond, you can always go with the KW V3 coilovers!
      10-27-2008, 06:12 PM   #10
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
next time ride in my car and i'll ride urs in front of u so u can see it. ur car was like a basketball
not that bad, but definitely bounced more, dont tell me u didnt expect that though!
      10-27-2008, 08:03 PM   #11
KKSigs
M4 CSL FBG
KKSigs's Avatar
Drives: M4 CSL FBG
No problems for me, still rides great.
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World
08' E92 M3 Jerez Black
      10-28-2008, 07:43 PM   #12
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
How many hours did you guys pay for install? Also what's the rate?
      10-29-2008, 12:33 AM   #13
MVEED3
Drives: '16 GT4
Springs are a DIY if you've done your fair share of wrenching. The only special tools required are MacPherson strut type spring compressors which you should be able to rent for free. Search for the DIY in the e90post section. Otherwise, I'd expect about 2.5 hours of labor.
Allen
      10-29-2008, 03:58 AM   #14
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
I was quoted $400 from evosport... or could go with Long Tran.
      10-29-2008, 03:10 PM   #15
leewoods18
Drives: F10 550 M sport
I've had no problems so far. Feels planted and handles great...it would be subjective to state if the handling is better or the same, but it hugs corners unbelieveably. I do not feel it is "bouncy", but the most important test it passed= the wife test. She falls asleep in the car all the time without a complaint, so that is the most important test. Perfect stance btw....always kinda bothered me that the M3 sat a bit tall and the 335's have a better stock stance...now it looks perfect.
      10-29-2008, 06:28 PM   #16
Eurotrash8
Eurotrash8's Avatar
Hong Kong
70
Drives: 2008 E92 M3
Doh Mah.....
      10-30-2008, 12:57 PM   #17
tszene
My experience was that at high speeds the car feels a little less stable, kinda hovering over the road, not as precise as with the stocks. I dont know if that is for real or just my imagination. noticed it after i took her to the track. First with the stock springs and 3 days later with the H&Rs and now i wish i changed to coilovers.
But it looks great though i have to give them that.
      10-30-2008, 01:03 PM   #18
MVEED3
Drives: '16 GT4
Get an alignment and try again.
Allen
      10-30-2008, 01:25 PM   #19
tszene
Allen
I did it when they were installed and then again 4 weeks later. It could be that my expectations were too high.
Thanks for the advise though.
      10-30-2008, 02:42 PM   #20
armyav8tor
n1smo
armyav8tor's Avatar
Drives: E92 M3
Thanks for the feedback! Cross another mod off my list.
      10-31-2008, 03:45 AM   #21
spyderco10
spyderco10's Avatar
Drives: AW E92 M3 6MT
ride is good with the H&Rs. However, I too was surprised that H&R didn't make these springs stiffer. they feel maybe only about 15% stiffer than stock. I would have actually liked a stiffer spring. it feels too soft over speed bumps and driveways. I had H&Rs on my '03 Mini S, and those were pretty stiff.
but back to the M, i guess it's the perfect balance between looks, handling, and ride
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16
      10-31-2008, 07:29 PM   #22
Technic
Technic's Avatar
2295
Drives: 2021 i3S, 2024 i4 M50
x2
m3post
