04-08-2021, 02:55 PM | #1 |
Rep 849
Carbon Fiber Roof Clearcoat lift or Fade? Can it be paint corrected?
Is this the clearcoat lifting or just a little faded (look at where the white glare meets the seem of the black plastic trim).
Can this be paint corrected or is the start of the dreaded clear coat peel? I bought the car last year and did a 3 step correction and ceramic coating. It has always been garage-kept under my ownership, but obviously not sure about the PO.
Current: 2016 F82 DCT M4 FBO Daily.
04-08-2021, 02:59 PM | #2 |
2018 M3 ZCP / 06 330xi
211
Rep 278
Thats def peeling/fading away. I have the carbon roof and really hate that I have to think about this. I would 100% trade it in if it happens.
04-08-2021, 03:10 PM | #3 | |
Rep 849
I got quoted $900 by a shop that has done this a million times if i do need to eventually do this. To be honest— it's not bad yet, so not worth spending the money yet. I'm just trying to see if there is a way to mitigate this from getting worse.
04-08-2021, 03:22 PM | #4 | |
Rep 1,481
04-08-2021, 03:54 PM | #5 |
Rep 502
That looks like the start of clear cost failure but it's not that big of a deal. People just get it sanded down and recleared and then throw some PPF on it and it's good as new. You just gotta find a shop that's willing to work with carbon fiber because I've heard there's many that are too scared to do so
04-08-2021, 05:06 PM | #6 | |
Rep 849
I know a shop willing to do it, but the picture and spot looks SO much worse than it really is. considering how i don't DD this car and it sits in a garage, i'd love to see if there something i can do (possible extra ceramic coat layer on that spot) to make sure it doesn't get worse for the next few years.
04-08-2021, 05:27 PM | #8 | ||
Rep 849
04-08-2021, 05:28 PM | #9 |
Rep 849
Lol i'm in south florida. I have this "issue," while my buddy has a sunroof that literally SHATTERED...
04-08-2021, 06:03 PM | #11 |
Rep 624
04-08-2021, 06:05 PM | #12 |
Rep 502
If you don't want it to get worse PPF is probably what you're looking for, I don't think ceramic coating will help that much. However I feel like you can easily DIY fix it or make it look significantly better. Just sand that spot a bit and get a can of UV resistant clear coat and put a couple coats on that small area. Would probably end up looking perfect from 3+ feet away and not even noticeable when standing up close if you didn't know about it. And worst case if it doesn't work then you just have that shop fix it right and clear will be stronger than whatever cheap crap BMW used from the factory
E92TiAg335i218.00 |
04-08-2021, 06:11 PM | #13 |
Rep 849
04-08-2021, 06:12 PM | #14 | |
Rep 849
04-08-2021, 06:19 PM | #15 |
Rep 137
This can be fixed. It was an issue on the E9X and it appears to be even worse on the F8X. The clearcoat just doesn't seem to do well in places where you have high outdoor temperatures.
You can take it to a specialist who can fix this for you and remove the shitty clearcoat and give you 2-3 layers of new epoxy so it will never happen again. Check out the video below. |
04-08-2021, 07:13 PM | #16 |
Rep 240
04-11-2021, 03:02 PM | #17 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
I think a black roof does make the car look more aggressive, so I did wrap my roof in black. Definetely prefer it over a white roof.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
