10-28-2008, 03:46 AM | #1 |
Rep 1,973
When installing springs how tight do you tighten the top perch nut?
One thing I've always wondered when I install suspension is how tight should the top perch bolts be tightened? Since the strut tower is threaded, what if the two sides are uneven? Couldn't that make the ride height different on both sides?
I've attached a pic (thanks Speedtrap for the borrowed pic). Say for instance the top nut is tightened to 1 on one side and 2 on the other. Won't the ride height be different on both sides? Or is the general rule of thumb to make both sides about even? Also ... if you tighten both sides to position 1 or both to position 2 won't that yield different ride heights? That's a good inch right there. I know those positions are extreme ends of the threads, but I'm just trying to make my point here. Or am I just being overly anal? Haha.
MDCT ... so you can drive and eat a hamburger at the same time. |
10-28-2008, 08:51 AM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
The position of the nut has no affect on ride height. It just affects the maximum droop the suspension can acheive. Ride height is determined by the spring perch on the strut.
10-28-2008, 11:31 AM | #3 |
Rep 1,973
Is that true? Here's another picture that again shows the extreme cases. Would these two setups yield different ride heights? Or is it the spring rate that is determining the ride height?
10-28-2008, 11:45 AM | #4 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Lower nut looks like more preload to me, car won't have much sag which could be undesirable.
10-28-2008, 11:47 AM | #5 | |
Rep 13,001
The ride height will be determined by the spring itself and the shock/strut base position (the "sleeve" where the bottom of the strut is inserted) as previously explained. |
10-28-2008, 12:00 PM | #6 | |
Rep 1,973
10-28-2008, 12:47 PM | #7 |
Rep 13,001
... then we would not be talking about the same setup, as one strut will compress the spring more than the original strut, something like a coilover vs. standard strut.
10-28-2008, 03:28 PM | #10 |
Rep 1,973
I think I asked him in a thread before ... the one where he showed some pics after his drop and he didn't torque the bolts to any specific value.
10-28-2008, 08:27 PM | #12 |
Rep 1,973
I think as long as the uninstalled spring is not compressed more than it would be with the weight of the car then it should even out.
10-29-2008, 12:15 AM | #13 |
Rep 961
The top of the spring sits on a spring perch that's mounted to a bearing that's bolted (with three small bolts) upside-down inside the fender. The bottom of the spring sits on a perch that's clamped to the top of the damper body. The spring sits between these two perches.
The nut you are wondering about in the original post just keeps the damper rod in place - too loose and it will rattle, too tight and it will damage the threads and maybe the rubber bushing it sits in the middle of. Other than that, it has no effect on the ride height. |
10-29-2008, 12:49 AM | #14 |
Rep 425
You'll feel when the nut makes contact, sandwiching the washer assembly. IIRC, a 10mm socket fits over the top of the shock shaft. I used a ratchet on that and an open-end box wrench on the nut and squeezed to an approximated 18-20ft-lb. RealOEM doesn't have torque specs so I assumed this based on previous M3 specs. You can always torque the nut down after the assemblies are installed on the car. This may even be easier since the shaft shouldn't spin with the car on the ground under the spring's tension.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick 2016 Agate Grey GT4 PCCB LWB 2013 HP4 Competition |
11-21-2008, 06:38 PM | #17 |
Moderator
673
Rep 4,737
UPDATE:
Tighten to 64Nm! The tightness of the nut WILL slightly affect the position of the guide support and therefore the ride height. This is torque spec from BMW. |
11-21-2008, 06:58 PM | #18 |
Rep 2,867
I tightened this up today being that I had that clunking sound. However, I did not tighten it with the torque measurer being that the dealer wanted me to leave the car there for the day for something that would take 5 minutes. So I took it to my mechaninc, he tightened it down with a wrench and the sound is gone. Didnt turn too much but there was deff some room.
01-20-2015, 11:49 AM | #19 |
Rep 4,429
Great info
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
01-23-2015, 04:22 PM | #20 |
Retired Curmudgeon
2985
Rep 4,047
Except the ride height argument is wrong...
The bearing rides on the shaft collar. The tightening of the nut serves to hold the strut in position in the collar. It does nothing to the ride height unless your car sits with the shocks fully extended, which it doesn't... I'm not even sure the torque number is correct. I'll have to look at the manual to be sure.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
01-23-2015, 04:30 PM | #21 | |
Rep 4,429
01-23-2015, 04:44 PM | #22 | |
Retired Curmudgeon
2985
Rep 4,047
If you ever have to do this again, make sure you don't spin the shaft of the strut when you are tightening the nut. In some shocks this can damage the valve body. Not saying you did this time, but sometimes people get carried away tightening things!
