05-01-2021, 09:42 PM | #1 |
Rep 195
**HELP please** Check Engine Light codes: P2629 & P0491
I have a 2011 M3 and recently encountered a SES “CC-ID 31” Increased Emissions. My car runs fine, but this SES comes on every time I drive the car.
I also pulled the following codes w/ my OBD2 reader: P0491 - Secondary Air Injection System Insufficient Flow Bank 1 P2629 - O2 Sensor Pumping Current Trim Circuit/Open Bank 2 Sensor 1 I have cleared the codes several times, but they come back after about 10 miles of driving. My car is currently bone stock with about 60k miles. Should l replace the drivers side pre-cat O2 first according to the P2629 code? Is it possible something simply came loose like a wire? What is required to clear the P0461 code? Thanks for your help! Last edited by HadesM3; 05-04-2021 at 12:39 PM.. |
05-08-2021, 01:04 PM | #3 |
Rep 935
Drives: E90 M3
What have you looked at so far?
I'd check all the connections to the secondary air pump, the line that runs to the elbow of the intake and back of the plenum. Make sure they're tight. Basically anything connected to the SAP needs to be looked over. O2 sensor may be a secondary fault due to whatever is going on if I had to guess. How many miles? |
HadesM3135.50 |
05-09-2021, 06:05 PM | #4 |
Rep 844
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
I just got P0491 as well as an o2 code. I cleared both codes and the SAP code came back and the o2's came back later on. I replaced the primary o2's, but the SAP code still remains. P0491 which also shows up As 27B0, is calling for the secondary air injection control valve. I'm about to replaced both banks and the hose that connects to them.
HadesM3135.50 |
05-10-2021, 12:11 AM | #5 | ||
Rep 195
My car has about 60k miles. Quote:
Thanks for the advice guys! |
05-10-2021, 05:57 AM | #6 |
mTekMods
2161
Rep 2,912
Theyre both mounted upside down on the back of the engine also attached to the exhaust manifold heat shield, the upper nut and heatshield bolt are fairly easy to get out but the lower nut sits pretty recessed in and is covered by the manifold heat shield, most deep 10mm sockets arent enough to get in there, you'll need a stub of an extension to take it out.
HadesM3135.50 |
