05-15-2021, 02:23 PM | #1 |
Rep 365
Preventative maintenance question
I just got my regular oil change service done. Have a 2017 M3C - zero issues and only have around 33.5k km. The dealership recommended that have them perform engine coolant exchange service as a preventative measure. That’s not included in the no cost maintenance under the warranty period (I’m in my last year). Is this a preventative maintenance most are getting done? I had read other posts about potential issues with the coolant tanks. Not sure if this is a preventative service to prevent those types of issues in the future.
05-16-2021, 06:47 AM | #2 | |
Rep 408
The coolant expansion tank does have issues with leaking at the seams, but that is a physical mechanical issue with the tank itself and replaced under warranty. Changing the coolant won't have and effect on the tank itself If you're still under warranty, I would suggest looking into the condition of your expansion tank and having it replaced under warranty in which would be the time to flush the system because it would be opened up at that time. Picture of a good expansion tank with no white coolant residue along it's seams. |
05-16-2021, 08:27 AM | #3 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
No need for coolant flush in the S55, unlike the N55/B58 engines. Brake fluid flush is recommended every 2 years, though.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
05-16-2021, 08:53 AM | #4 |
Rep 433
Things to replace on S55 engine on a regular basis depending on how you drive/track:
Oil Brake fluid Differential fluid 6sp manual transmission fluid Spark plugs Belt Suspension bushings, brake pads/rotors and (valve conver, oil filter/cooler, oil pan) gaskets need to be monitored on a yearly basis for any wear! You should also keep a eye out on your Intercooler for leaks! |
05-16-2021, 11:23 AM | #5 |
///M SubDriver
1844
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
Old school maintenance mentality would differ and recommend flushing the coolant every two years, regardless of vehicle make or model. Engine coolant tech (including the blue stuff BMW uses) has not changed much over the years. Despite what BMW may tell you, no fluid is a lifetime fluid. Even though it is a closed system, the fluid will still break down over time. Back in the day before "included maintenance" BMW used to recommend flushing the coolant every 2 years.
If you don't do it, not the end of the world. But typically a coolant flush/fill at the dealer is not that expensive - even by BMW standards (sub $200). And of course there is always DIY, which is my preferred method..
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
05-16-2021, 02:30 PM | #6 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
05-16-2021, 05:59 PM | #7 | |
Rep 365
05-16-2021, 06:01 PM | #8 |
Rep 365
I had the brake fluid flush done last fall, as part of the regular service. I’ll take a look at the exact wording for the recommended service (I do remember it said it is not required, but is recommended because of the coolant colour).
05-16-2021, 06:09 PM | #9 | |
Rep 365
05-16-2021, 06:12 PM | #10 |
Rep 365
05-16-2021, 08:36 PM | #11 | |
Rep 433
05-16-2021, 09:31 PM | #12 |
///M SubDriver
1844
Rep 2,787
Aww, it is not that bad, especially with the right tools (like a vacuum fill tool, which I have ). But I actually had my coolant flushed following a warranty expansion tank replacement…
