11-01-2008, 10:35 PM | #1 |
Moderator
675
Rep 4,737
DIY: Aftermarket Spring Install
The process is very similar (with some simplifications) to regular 3 Series' install: http://www.e90post.com/forums/showthread.php?t=15397
All the bolts and nuts that need to be removed are circled in red. BMW recommends replacing all nuts and bolts. Torque specs: http://www.m3post.com/forums/showthread.php?t=183005 I've done this so many times since when this thread was written. Now updated for 2010 Best Practices: Front Axle: 1. When removing the front springs: use a jack and push up the front suspension to compress the spring, and then put on the spring compressor. This will save you a lot of time. 2. The strut piston rod can be pushed into the shock with hands. Rear Axle: 1. When loosening the bolts: loosen the shock bolt first, the camber arm/wheel carrier bolt second. 2. When tightening the bolts: tighten the camber arm/wheel carrier bolt first, the shock bolt second. 3. It may be very tough to align the wheel carrier with the camber arm. Try jacking up the camber arm, and use a wrench as a level to position the parts. 4. When aligned correctly, you should be able to push the outer bolt completely through the camber arm, without any turning. This bolt is tightened by the nut. Last edited by rzm3; 01-03-2010 at 04:24 PM.. |
11-06-2008, 08:55 PM | #5 |
Rep 1,973
SWEET! Any shots of the rear install? I know it's probably exactly the same as a normal 3 series.
MDCT ... so you can drive and eat a hamburger at the same time. |
11-06-2008, 09:12 PM | #6 |
Moderator
675
Rep 4,737
11-06-2008, 10:23 PM | #7 |
Rep 1,973
Holy shit, I fail. My bad! Thanks again for the specs and pics. Time to order my springs.
12-19-2008, 05:14 PM | #8 |
Rep 2,091
How difficult was it using the spring compressor? I have done tons of coil-over installs before on my various cars including two e46 M3's, but have never installed drop springs. I recently ordered some H&R springs and plan on doing the install myself. Am a little worried about using the spring compressor in fear that it will slip or fail and the spring will shoot out and hurt someone, the car, or something else. Is it straight forward using the compressor and is it pretty sturdy? Would love some input on this. TIA.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
12-19-2008, 07:17 PM | #9 | |
135
Rep 1,825
The original Hid angel eyes for sale now on ebay
User name lmims526894rou Or contact me at chrism9551@aol.com |
12-19-2008, 09:59 PM | #10 | |
Rep 2,091
http://shop.oreillyauto.com/ProductD...egoryCode=3492 http://www.sears.com/shc/s/p_10153_1...0070515x00001c
12-20-2008, 03:26 PM | #12 |
Rep 2,091
That's good to know!
12-22-2008, 03:09 AM | #14 |
135
Rep 1,825
yep thats where i always get them from or advanced
02-18-2009, 12:56 PM | #15 |
Bored at work....
894
Rep 5,397
Bump so I can find this thread in the spring too.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
02-19-2009, 07:44 PM | #17 |
do a wheelie!!!
156
Rep 929
Drives: E46 M3 - '72 2002 - '65 Impala
how long did it take?
~Adam
02-19-2009, 10:00 PM | #18 |
Commander-In-Chief
2206
Rep 8,950
02-20-2009, 11:48 AM | #19 |
do a wheelie!!!
156
Rep 929
~Adam
02-23-2009, 11:55 AM | #20 |
do a wheelie!!!
156
Rep 929
DID IT!!! took me and a friend about 2.5 hours. It was super easy. we had planned a 6 hour install like the thread said. Thanks rzm3 for the DIY helped out a lot. and thnks for all the torque specs too looks great now
~Adam
02-23-2009, 03:19 PM | #22 | |
Bored at work....
894
Rep 5,397
Nice to hear!!
