06-08-2021, 07:55 PM | #1 |
Rep 2
Why is RPM needle stopping at 3000 at startup. Help
I have a 2015 M4. When u turn on the car the RPM needle does a sweep to 8500 but stops at 3000 RPM for 2 seconds before going back to off. The same things happens at startup where it pauses at 3000rpm before going to idle. The car has both JB4 and BM3.
Whats causing this? |
06-08-2021, 07:57 PM | #2 |
/M Enthusiast
1603
Rep 1,619
Let us know what you find?
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
06-08-2021, 08:02 PM | #3 | |
Rep 845
It does it on mine when i select map 3. The issue is it might be that your cruise control is stuck. Try flashing the car to stop from BM3 back to stock then reflash. |
06-08-2021, 08:32 PM | #4 |
Rep 186
Drives: BMW X3MC LCI
Mine occasionally does the same where it will hold at whatever map number you’re on. I think it’s meant to show you which map you’re on at startup but it doesn’t always happen. I don’t think it’s anything bad as long as it eventually shows your RPMs
Pagizzle0.00 |
06-08-2021, 08:48 PM | #5 | |
Rep 2
06-08-2021, 09:21 PM | #6 | ||
Rep 845
