07-01-2021, 08:42 AM | #1 |
Rep 95
Car not sounding the same downshift upshift
Hey guys hope all of you are well, i got an M4CS so i dont know if its just me but i put gas in a not so known gas station called westar it was the closest didnt think much of it put 93 as always but then something happens every 3 seconds the gas would stop pumping so i had to press the gas trigger for it to pump every 3-4 seconds so it can fill up so this is where the issue pops up now my car doesnt sound the same with pop and crackles when i downshift or upshift like there is still crackles and all that but they are not as aggressive or loud then prior to when i went to that gas station. Any advice ?
I dont know what it could be |
07-01-2021, 09:53 AM | #2 |
Sad ///M noises
4197
Rep 1,798
Could be a case of bad gas or bad gas pump.
I'd remove the fuel and put in new and see what happens. Or take it to a shop on a flatbed to avoid driving it in case it is something serious. |
07-01-2021, 09:57 AM | #3 |
Rep 433
If its hard to drain all the gas you can try buying a bottle octane booster and see if that helps!
07-01-2021, 10:00 AM | #4 |
Rep 95
07-01-2021, 10:01 AM | #5 |
Rep 95
I will wait for the gas to be almost out of gas so i can fill it up at the gas stations I usually go to
07-01-2021, 10:22 AM | #6 |
Rep 10,720
Drives: M4 CS. Former G82, x2 F82, F80
07-01-2021, 11:27 AM | #7 |
Rep 2,368
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Keep your rpm below 3k and avoid high speed/highway until you get a fresh tank.
Pass me if you can.
07-01-2021, 04:59 PM | #10 |
Rep 1,988
I've been there. I also notice my car drives better right after I wash it 😊. Keep us posted!
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO 2016 340i xDrive : AW/CR (sold) |
07-01-2021, 05:08 PM | #11 |
Rep 95
Thanks man, i will. Im putting gas later today i got 30 miles left
07-03-2021, 07:16 PM | #12 |
///Multiple
2993
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
I'm not sure I understand your logic in waiting until you're practically on empty before you put in better fuel. If the problem was caused by low octane, or even by water or sediment in the gas, you're far better off filling up ASAP with good gas from a top-tier gas station and diluting that bad gas with better fuel. If you wait until you're empty, you're just running the car on bad gas for longer and the remaining dregs may actually make the problem worse.
And don't buy cheap gas! Always buy premium, top-tier gas! (Google it)
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
07-03-2021, 09:49 PM | #13 |
Rep 1,628
07-03-2021, 10:01 PM | #14 |
Rep 1,988
Brake dust? What's that? I run akebono ceramics 😎
07-04-2021, 12:12 PM | #16 | |
Rep 69
SD ///M42993.00 |
