07-08-2021, 01:00 PM | #1 |
Rep 1,158
Drives: 2011 BMW M3 2020 BMW M5C
CarPlay retrofit with RCA output?
I purchased a CarPlay headunit from AVIN, planning to install it since the car came without BT audio. The largest downside I see is that it outputs to AUX, are there any headunit a that are more plug and play to the factory speaker harness or even have their own RCA output?
I initially planned to run a better AMP and upgrade the speakers with larger sub included. It's still doable but obviously would sound and function better if it had proper input from the headunit. I don't really care about the CD player or radio working if I had to bypass those.
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
07-10-2021, 03:56 PM | #2 |
Rep 3,332
No such units seem to exist. I think this is ultimately a limitation of the MOST Bus and how aftermarket companies have built their units. I don't think it's impossible to build design such a thing, but I suspect most vendors decided that using the AUX to not remove OEM functionality was the tradeoff that made the most sense and wouldn't require any coding or other complexity.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
