BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Exterior / Cosmetic Parts
      07-14-2021, 01:41 PM   #1
lowkey_domm
lowkey_domm's Avatar
62
Drives: 2008 E92 M3, 2012 E70 X5D
E92 alpine white trunk fs
BIMMERPOST / Classifieds
Asking Price:
USD 200.00
Or Best Offer
Item Interest
OEM E92 M3 Alpine White trunk
Drilled for GTS wing base.
Base Plate holes are 30 inches apart.
No shipping located in Socal
IG: lowkey_domm
      07-14-2021, 06:08 PM   #2
x Spades x
Drives: BMW E46 M3
Pm sent
      07-20-2021, 12:30 PM   #3
lowkey_domm
62
bump
IG: lowkey_domm
      08-09-2021, 02:15 PM   #4
lowkey_domm
62
bump
IG: lowkey_domm
      08-10-2021, 06:27 PM   #5
x Spades x
Drives: BMW E46 M3
Ugh... I'm thinking hard about this.
Is this an LCI trunk (as in no key hole)?
Also, it looks like the back hole is a little off... does that affect the install at all?
Finally, can you post install pics from different angles?
      08-11-2021, 10:57 AM   #6
lowkey_domm
62
Correct LCI trunk no key hole.
I believe you're referring to the wing mount holes on the trunk, they're not perfect because I went from a GTS wing to a GT4 on the same trunk so I had to notch the hole some more. Does not affect install cause you'll use either washers or backing plate for your wing and the base plate hides the holes so you cannot see the holes from outside.
IG: lowkey_domm
Tags
e92, trunk
m3post
