BMW M3 Forum (E90 E92)
      11-06-2008, 08:05 PM   #1
JonM
Drives: E90 M3 Sedan
Let's Install Alcantara Tricolor ///M-stitch Boots
Start with the shift boot. To remove it, pull up by pinching the leather along the 2 longest sides. The boot is snapped into the console and it will come up when you pull.
Once the boot is unsnapped, reach in and disconnect the wire harness that powers the lighted shift knob.
Pull the shift knob straight up. Use 2 hands. Be careful not to hit yourself in the face when you do this, or hit your knuckles on the rear view mirror. Remember: do not twist the knob as you pull. It will unsnap from the selector rod.
If you are re-using your stock shift knob, you will need to cut it off of the stock boot and glue the exposed leather onto the rim of the shift knob. Use a good contact cement for this like 3M Wedgewood that you can buy at Lowes stores. Turn your aftermarket or replacement boot inside out. Feed the wire harness for your lighted knob (if you are using one) through the neck opening of your new boot. Slide your new boot onto the selector rod. Line up your knob and snap it onto the selector rod.
Connect the wire harness. Turn your boot right side out and snap the new boot onto the center console.
Then move on to the e-brake boot. To remove the stock boot, pull up at the back of the boot by pinching the leather with your fingers. No tools.
Turn the boot inside out over the e-brake handle.
Cut the factory tie wrap off at the neck of the boot and slide the boot off of the e-brake assembly. Turn your aftermarket boot inside out and slide it back onto the e-brake assembly. Re-install a new tie wrap and make sure you line it up to the groove in the brake handle. Take care to make sure you secure the entire neck of the new boot, all the way around the handle.
Turn the boot right side out. Snap it back into the console.
Good job. Remember to use genuine Alcantara and not Ultrasuede or a lower grade product. BMW always uses real Alcantara which is actually a very dark gray.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      11-06-2008, 08:23 PM   #2
Straz M3
Never Lose
Straz M3's Avatar
50
Drives: 2011.75 E92 M3
Looks great...going to order mine now from LeatherZ. I've done this so many times in my old cars but I've never reused the stock knob. Was it hard to cut the leather and glue it down? I feel like it won't look flush if I do this. Any pics of exactly how you did it? Thanks!
'11 Melbourne Red Metallic / Black/Fox/Fox 6MT E92 ///M3
ZCP | Convenience Package | Premium Package 2 | Heated Seats | Enhanced Premium Sound l BMW Apps
      11-06-2008, 08:56 PM   #3
MDCTFTW
Drives: E92 DCT
Nice writeup! Not sure I like the look over stock though.
MDCT ... so you can drive and eat a hamburger at the same time.
      11-08-2008, 12:08 PM   #4
Seth_Horwitz
Tired of feather footed //M drivers
19
Drives: 330ci, 911 Turbo X50
Sorry if this has been asked before, but can the DCT boot be swapped as well? Nice install.
      11-08-2008, 01:09 PM   #5
Speedtrap
United Kingdom
57
Drives: A very fast car :)
Thanks for sharing..a great mod
      11-08-2008, 03:35 PM   #6
Big Windy
Big Windy's Avatar
Drives: None
would probably fit well if you had an alcantara wheel, but it seems a bit out of place to me.
      11-08-2008, 06:21 PM   #7
bmstyle71
bmstyle71's Avatar
115
Drives: jet black e92 m3
It's nice but doesn't completely blend in with the rest of the interior around it. The shift knob is black then all of a sudden it gets to a brownish color.
      11-08-2008, 08:36 PM   #8
mvagusta
Drives: 2008 m3 coup
I have a stock m3 knob for sale pm me..... Since i changed mine for a issota...I'll put pictures when i'm done with the interior...
      11-09-2008, 12:18 PM   #9
JonM
Yes.
I hear you. Black leather with M stitching is my personal choice. Or, if it must be alcantara, then the knob should/could be upgraded to alcantara too.
Jon Maddux
x5nut.blogspot.com
      11-09-2008, 12:19 PM   #10
JonM
It is easy. Be careful not to cut the wire harness. Leave about 1/8" leather from the bottom of the shift knob. Paint the inside of the leather and the end of the knob with contact cement. Wait 10 minutes, then press the leather in place. You can clamp it for an hour if you want, or hold the knob with some pressure for a few minutes.
Jon Maddux
x5nut.blogspot.com
      11-09-2008, 07:12 PM   #11
youyou
youyou's Avatar
Drives: Porsche 997 C4S
I would definitely get this in black leather with ///M stitching.
Is it available?
Thanks
      11-10-2008, 04:33 AM   #12
dar2008
dar2008's Avatar
United Kingdom
303
Drives: E93 M3 and E92 M3 Comp
This just looks SO wrong! The sort of thing my 12year old would put together in needlework classes,... nice, but not in a 70k sports car
      11-10-2008, 06:40 AM   #13
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
Man, why would'nt just take off these covers, take it down the cap shop that embroiders caps and ask them to sew a Red & Blue stitch down each seam. This way you still have the nice leather and end up with the BMW look stitching.
It would probably cost $10.
My $0.02
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      11-10-2008, 09:56 AM   #14
JonM
My $0.02
If you think that would look good, you are welcome to do that.
Jon Maddux
x5nut.blogspot.com
      11-10-2008, 09:57 AM   #15
Eurotrash8
Eurotrash8's Avatar
Hong Kong
70
Drives: 2008 E92 M3
Nice DIY..........is that a civic or a Neon?
      11-10-2008, 05:00 PM   #16
watrob
watrob's Avatar
Australia
140
At least it would match the steering wheel!
      11-10-2008, 05:24 PM   #17
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
i have a shift boot and ebrake boot for sale btw.... PM me guys... i bought them and changed cars and never had time to do it....
oh they're leather, not alcantra btw
      11-10-2008, 05:27 PM   #18
watrob
watrob's Avatar
Australia
140
Got some pics?
      11-10-2008, 09:46 PM   #19
Blip Bavarian
salivator
Blip Bavarian's Avatar
Drives: 16 GT4, 14 X5 V8 & 91 E30 LS1
I always love your DIY's, and think that this looks pretty good. But shouldnt the stitching be red purple and blue, instead of red white and blue?
keep up the great DIY's
      11-11-2008, 12:36 AM   #20
TTG
TTG's Avatar
Drives: M340
Sorry, stock looks so much better IMO......
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      11-16-2008, 04:38 PM   #21
Saturn
Drives: E92 M3
Nice DIY.
I'm wondering if it is possible to get shift/ebrake boots in CF leather? Is the material flexible enough?
      11-19-2008, 04:18 PM   #22
ersin
ersin's Avatar
Drives: 17 YMB F80 M3
I've seen some Alcantara boots. They look better in person, but I think I would like plain stitching on Alcantara better. What looks very high class is Alcantara roof lining like in the E39 M5.
2017 F80 YMB.
m3post
