07-25-2021, 09:43 PM | #1 |
Rep 12
Turner rear diffuser
Anyone else out there running the carbon fiber rear diffuser from Turner? Wondering how the fitment has been for others as this thing has been a catastrophe for me. I exchanged my first one because of fitment issues and the replacement was a bit better though the tabs that clip into the bumper didn't lock well. I thought I had it solved with some double sided spoiler tape to help it stay clipped in but that was misguided. It popped off on me while I was driving last weekend and got run over by another car.
07-26-2021, 02:16 AM | #2 |
Rep 892
Drives: F87 M2CS
wow that sucks man. you have any pictures of the fitment prior to it falling off?
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
07-26-2021, 03:39 AM | #3 |
Rep 4,203
Wow it should have not fallen off..... most all diffusers have at least 2 screws that secure the bottom. Interesting if it does not
Silverlining_m21743.50 |
07-26-2021, 05:54 AM | #4 |
Rep 334
Drives: 991.2 C2S
I have it as well. The install was super frustrating to say the least. The two screw holes to attach it weren't exactly perfectly lined up. I used a dremel to sort of stretch the one hole a few mm's and that helped. But the middle section was confusing as there was no apparent way to attach it there. With only the two outer edge screws it would pop off easily. In my frustration with it, I pushed super hard in the middle trying to seat it and it went "snap" into what seemed like it's designed place. That was over a year ago and it hasn't moved since. So on the back side of the diffuser there are clips and those clips pop into place with the right amount (read frustrated amount lol) of force.
Good luck! I love the diffuser!
2025 LCI Skyscraper/Silverstone M4 6MT week 16 build status 193 at the port
2019 Black Sapphire/Coffee G05 X5 X50i MSport | Stock AF Grocery Getter 2013 Titan Silver BMW K1300S | Full Akro Exhaust Retired: F82 M4 6MT, F15 X5, F30 328i, E46 330Ci, E46 325Ci |
07-26-2021, 06:52 AM | #5 |
Rep 1,238
Wow the only ebay part on my m4 is the cf diffuser and it sounds like it has better fitment than the Turner model. I've replaced the diffuser on a few cars now and all have been a frustrating, tight fit at the very least. Curious how it came off if it was securely screwed in?
My best and preferred method is to place it somewhat in place, lightly thread the screws in so they are very loose, fit the diffuser into its clips on side to the other. Fully screw. Double check clips. Super sorry you lost it. I would say my ebay diffuser is a 8/10 and most untrained eyes think its oem. I can look up the seller if you want the info. Let me know. Cheaper than turner, and sounds like a better fit
2023 M2. ZB. Manual.
2024 m235i |
07-26-2021, 10:36 AM | #6 |
Auto/DCT Zealot
501
Rep 377
Drives: M3, Miata
Shame that people are having trouble with the Turner diffusers - I was thinking of doing the dual Turner diffuser but it's not looking like I should.
For those of you that have had one or both parts: ignoring fitment, how was the carbon fiber quality? |
07-26-2021, 10:39 AM | #7 | |
Rep 12
sabrina528.00 |
07-26-2021, 10:42 AM | #8 |
Rep 12
The build quality on both of mine were great. The fitment of the diffuser itself was great, it's just where the tabs to lock it in, in addition to the screws didn't line up to create a really solid connection. It looks OEM and were it not for it popping off I would be really happy with it. I was hoping to get that secondary diffuser at some point too cause it looks awesome.
07-26-2021, 10:44 AM | #9 | |
Rep 12
07-26-2021, 10:46 AM | #10 |
Rep 12
It has 2 screws on the sides though that's not enough to hold it in place long term. If I had to guess I think since the front of the diffuser popped out and it was flapping a bit it could've broken one of the tabs the screw uses. Mulling if I go cheap ebay route or pony up for OEM now.
07-26-2021, 11:30 AM | #11 | |
Rep 334
Drives: 991.2 C2S
07-26-2021, 12:46 PM | #12 |
Rep 29
I have a turner diffuser I'm not using. fitment was spot on and I had it on the car for 4 months without issue that includes normal daily use and extremely spirited driving. Maybe their supplier had a bad batch? It happens sometimes.
08-02-2021, 12:31 PM | #13 |
Rep 22
had the same issue. Could not for the life of me get it to snap in long term, just would pop back out.
The fitment as great and everything lined up perfectly except that tab. I just gave up on it and chalked it up to buying crappy parts lesson learned. |
08-02-2021, 02:35 PM | #14 |
Rep 12
Yup, it was super frustrating. Did you contact turner about it? I had my first diffuser replaced, the second fit better but still popped out here and there. I thought I had it in, but obviously not and now the thing is thrashed. They also won't respond to my emails on the topic which rubs me the wrong way.
