07-28-2021, 09:17 AM | #1 |
Rep 6
F15 air suspension issue. Car not lifting anymore
My sister went on holiday for a week and left her broken car with me. BMW X5 f15 2015.
I have done some DIY work on my own car, so I thought maybe I could try to diagnose and fix her car's suspension issue. Initially, she told me that one side of her car not lifting, so I right away thought it will be a suspension air bag. But once she actually brought the car to me, both sides are not lifting at all. Car sit with empty suspension bags now, I can't do a leak test on it. I cannot hear the pump trying to lift either. The car was not driven for few days, I wonder if the pump went into some sleep mode... Maybe the battery is not charged enough? I also checked 40a fuse, it is fine. Any suggestions on how I can identify the issue? I don't think that both airbags are so blown that they can't hold any air at all. Oh, and dash shows Chassis function restricted warning message. |
07-28-2021, 11:57 AM | #2 | |
Rep 2,520
https://f15.bimmerpost.com/forums/sh....php?t=1641660 https://f15.bimmerpost.com/forums/sh....php?t=1733505 https://f15.bimmerpost.com/forums/sh....php?t=1511949 https://f15.bimmerpost.com/forums/sh....php?t=1751937 Sounds like your compressor died trying to pump air into the damaged air bags leaking air. |
Maverik2594146.00 |
07-28-2021, 12:41 PM | #3 |
Rep 2,737
My bags looked fine and yet both sides would go flat.
And no holes could be found after inspection. I'd recommend just doing both at the same time as if ones blown the second may not be far behind. Got to fix the bags before playing with the compressor. You can burn the compressor out if it's just pumping air continuously. |
07-28-2021, 03:33 PM | #4 |
Rep 6
Thanks for replies.
I have a feeling that compressor is bad now because of leaky air bags as RED_Y_ says. But from the other forum threads that i read usually people get blown fuse when compressor fails, which is no the case here. I will try to remove compressor and test it using power supply. |
07-28-2021, 03:36 PM | #5 | |
Rep 6
07-30-2021, 03:59 AM | #7 |
Rep 6
I found that compressor is actually "working", I can hear a noise when I open the doors, but the car is not lifting.
I have removed the output hose from compressor and checked if air is pumping. And it is pumping, but I think its weak, I can fully block it with my fingers. I have taken the compressor apart to see if there is anything I can see obvious, but it looks clean (including venting solenoid), even dried out those little beans inside... those were half dry anyway. I have installed it back and checked, but still same weak output and car not lifting. I have ordered a new compressor, waiting now. |
08-03-2021, 04:55 PM | #11 | |
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
02-19-2022, 11:08 AM | #13 |
Rep 8
