08-13-2021, 07:12 PM | #1 |
Rep 310
Rod Bearings 70k miles PRE LCI
Thought I would post these for reference.
Car was completely stock up until the last 5k miles. Kind of sketch to see how bad they were! Curious if others with experience think this is normal wear?? |
08-13-2021, 07:21 PM | #2 |
Rep 1,076
"Normal" is relative with our family of engines. Knowing that, it is still excessive for the mileage, for our engines. I had mine changed out at 65k mi and it was a HUGE weight lifted off my shoulders. I bet you feel better now.
Davisca4552207.50 DrFerry6731.50 |
08-13-2021, 07:25 PM | #3 |
Rep 310
I really do! My mechanic said cylinder 2 crank had a small mark on it but should be fine. Said it was a ticking time bomb.
Davisca4552207.50 |
08-13-2021, 11:52 PM | #4 |
Rep 865
Good on you for changing those.
"Normal" rod bearing wear seems like a relative term around here. I used to think the whole rod bearing issue was an internet hoax. But just about every picture of rod bearings that I saw posted on the forum showed rod bearings that didn't look normal, so I decided to do the DIY for peace of mind. But even then, I was fully prepared to be mad at myself when I removed perfectly good bearings because of internet hysteria. I did the work on the original owner's lift. He also thought the rod bearing "hysteria" was overblown. He would say "The car was never left outside, I always warmed it up, and I always had the car serviced at 6000 miles." I had about half of the bearings replaced when the PO walks back into the garage. He starts inspecting the old bearing sets I had left on the top of the toolbox and says "These don't look right. Good call to change the bearings." As he turns to walk away, he slowly shakes his head from side to side and mutters "Fuckin previous owner." "Ticking time bomb" is no exaggeration.
Chris, 2008 E92 |
08-13-2021, 11:56 PM | #5 | |
Rep 310
08-14-2021, 07:56 PM | #6 |
Rep 1,076
08-14-2021, 08:24 PM | #7 |
Rep 310
No clue.. what was weird two is on bearing #2 there was this weird indent through the whole bearing that you could feel with your nail. Like it was grinding against something.
08-15-2021, 02:04 AM | #8 |
Rep 5,508
That looks "normal". The stock bearings look terrible when pulled out of most M3s. No amount of babying the car will protect the bearings or guarantee it won't wear badly. I'm glad I had mine done with extra clearance bearings.
It's cheap insurance compared to the cost of a new engine!
Auto Detailing Enthusiast!
08-15-2021, 05:23 PM | #9 |
Rep 155
Drives: M4; X4 M40i
I think it has to do with the original owners and if the let the engine oil warm up properly before getting on it.
OP good call. |
08-16-2021, 10:07 PM | #10 |
Rep 2,145
Drives: 2011 E92 M3
Warmup is insignificant compared to proper flow. When cold, the S65 protects itself with a reduced redline.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
08-19-2021, 09:41 PM | #12 | ||
Rep 155
Drives: M4; X4 M40i
