09-10-2021, 03:57 AM | #1 |
Rep 35
Big risk or Low risk on Android Auto without disconnecting battery
Hello everyone,
I bought an Android Auto module for my X5 and it is recommended to disconnect the battery before installation. As I have 2 batteries & the hybrid system, disconnecting batteries and reconnecting them always drive issues at the beginning from what I read. Do you think it is risky to just install the Android auto when car is fully off ? I will be carefull before I plug the different items... Any feedback is very appreciated ! Sam |
09-10-2021, 10:11 AM | #2 |
Rep 24
I heard about that too and was unsure about it like you. I have a 2016 and disconnected both batteries for a week to remove the DME. When I reconnected the battery there was zero issues and fired up just the same. I don't have a hybrid system though.
09-10-2021, 10:27 AM | #3 |
Rep 247
Same here, I have the 40e. I only disconnected the big 12v battery. I had 0 issues when installing my MMI.
If I had to do it again, I would probably disconnect the aux battery and disconnect the high voltage (not sure if it's for hybrid only, but link) - just in case, you're already back there anyways. |
09-10-2021, 11:31 AM | #4 |
Rep 30
I always disconnect all the batteries, including the high voltage, for safety reasons and wait about 15min for systems to shut off/discharge. No issues at all when reconnecting power back.
09-12-2021, 05:46 AM | #5 |
Love the X5, but R1 is life!
20
Rep 69
I went rogue. I initially had the carplay module and disco’d the batt when I installed it. I recently replaced that with an android HU leaving the batt connected. No issues. About a month later, my rear cam started cutting in and out. Not likely related but full disclosure.
The cam was replaced and I put the HU back in, no batt disco. No issues since. Go with the recommendation. I went this route after watching a few YouTube’s where the installer went straight for the head unit leaving the batt connected. |
09-13-2021, 11:09 AM | #6 | |
Rep 942
Drives: 2016 BMW X5
Tags |
android auto, battery, disconnect, installation |
