11-15-2008, 08:41 AM | #1 |
Rep 1,417
Shifting back to Park with DCT
I just looked at a White e92 M3 at my local dealer. The car is equipped with the DCT, the first E92 that I have seen this way. The SA suggested that I start the car which I did. The sound of the engine is great. I noticed that the car showed P on the dash, I am assuming this means the car was in Park. I put my foot on the brake pedal and tried shifting using the center consol knob. Now I must admit this is my first time using this shift knob, but I could not figure out how to put the car back in Park.
Can anyone with the DCT explain how this is done? I ended up shifting into R and turning off the car while I kept a firm foot hold on the breaks. Red
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
11-15-2008, 08:48 AM | #2 |
Rep 1,417
I ran a search prior to posting this. However I now see a prior post to mine. Good thing I am not the only one who is wondering about this.
Red
11-15-2008, 09:23 AM | #3 |
Rep 1,035
Eisenmann Race Performance/VRS front lip 1x1/VRS type II diffuser 1x1/VRS single side trunk with Fade/19" HRE C90's/RE SSK/H&R Sport springs /35% tint/Painted reflectors/Painted side markers with dark tint LED's/Tinted tail lights/Front grilles/Hardwire V1
11-15-2008, 11:19 AM | #5 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
http://www.m3post.com/forums/showthread.php?t=185637
It's not an automatic transmission. Don't think of it in terms of an automatic, think in terms of a manual. There is no "park" in a manual. In the DCT, they use "P" to equate to the times you shut down a manual car, put it in gear and pull the ebrake. P just means the car was in effect, put in gear for you when you shut it down. If the car is running while you are parked, you can't put it in "park", just like you can't put a manual in gear while you are parked (without holding in the clutch). Just put it in neutral, just like a manual, and apply the ebrake. Do not get hung up on the symantics of the use of the term "park". Anybody who can't understand this should be driving an automatic, which means this is not the car for you. |
11-15-2008, 11:30 AM | #6 |
Rep 2,496
if you put it in nuetral, it still goes back into gear (park) when you shut off the engine, so whats the point.
if you forget to set the p-brake the car will always go into park when you shut it off, so your good. there is just no Park gear while the car is on, so in that case, just set the p-brake. car wont go anywhere.
11-15-2008, 07:05 PM | #7 | |
Rep 545
The “park” pawl and park gear is just like those used in an automatic transmission. The pawl is engaged by an electric solenoid and released with hydraulic pressure when the engine is running. The park gear is visible in the first picture at the rear of the transmission on the output shaft. In the second picture you can see the park cable running from the shift lever area. This is the same arrangement used in most automatic transmission except the pawl is most often engaged and disengaged manually with the shift lever. This is a link to a previous post with the clutches shown with discription. See post #9. http://www.m3post.com/forums/showthr...04#post3529804 The M-DCT is not held in place by putting the transmission into gear like a manual transmission because the clutches used in the M-DCT cannot be engaged when the engine is not running. The M-DCT clutches are engaged (applied) with hydraulic pressure and there is only pressure when the engine is running. When the engine is shut down there is no pressure to keep the parking pawl disengaged (released) so it will move into the parking gear. The pawl is only about the size of the tip of your little finger so be sure to use the parking brake. As a side note the M-DCT cars cannot be push started because there is no pressure to engage the clutches without the engine running. |
11-15-2008, 07:22 PM | #8 |
Rep 1,887
Yes, I know how what happens when it goes into park.
When I say don't think of it as an automatic, think of it as a manual, I'm talking about how the the driver should interact with it. Don't think of it as "park". Don't think of it as an automatic. If you do, you will wonder why you can't put it in "park" while the engine is running and you are sitting waiting for something. If you think in terms of a manual, you won't think of this as a problem or think that BMW didn't think it through or that it is a dumb design. Coming from a manual, it didn't even occur to me that it was a problem... I knew that what this DCT does to go into "park" is putting the car in the same state that we normally do with a manual, which is having something keeping the car immobile besides just the ebrake. With a manual, we put it in gear. With the DCT, it engages this pawl. In both cases, this doesn't work if the engine is running. Thus, as far as operator interaction, it is more like a manual than an automatic. |
11-20-2008, 02:56 PM | #9 |
Rep 1,417
I suppose you get used to the shifter after some time, but why should it need time to get used to a shifter at all. I do think that BMW is now Over engineering many items on their cars these days. The gear selectors being one, the turn signals as another. I still remember the controls in my 2002’s. They were there only for one purpose and they moved just like any other make of car. Granted the turn signals were on the Right side of the steering wheel in the 2002’s.
How many years have people been selecting these items without a second thought to how they work, both Auto and Manuals. However the Manuals have a shift pattern to let you know where reverse is. This new gear selector in the DTC is not actually moving the gears into position like a Manual selector does. At this point I am not sure what it is doing. How do you change the shifting from the knob on the console to the paddle shifters on the wheel. Red
11-20-2008, 04:05 PM | #10 | |
Rep 1,887
I've been driving it every day for a month now. It all seems pretty much second nature. |
11-21-2008, 08:54 AM | #12 | ||
Moderator
7525
Rep 19,368
Even back in the days of the 2002, there were surely people who were confused by some of the car's functions. Consider your comment about the turn signal lever being on the right side. I'll bet some people were wondering where it was. Here's an idea, pretend like its 1972 and you just brought a brand new 2002. You have a question. There is no internet. So what do you do? You open the glove box and read the manual. Have you even tried doing that yet? |
11-21-2008, 07:37 PM | #13 | |
Rep 1,417
Obviously you have read your owners manual cover to cover. so I'm sure you can tell us all what it says about how to put your car back into park! Right OK, go, what does it say? Red
11-21-2008, 08:05 PM | #14 | |
Rep 208
"our superbly advanced technology allows you to have all the creature comforts of an automatic transmission, with the enthusiast's necessity for full control. Thus, at a standstill, just leave your vehicle in neutral and engage the parking brake. After you are done with your Big Mac purchase, disengage the parking brake, put the car in drive, and drive away you two-pedaled street-demon!" You know... more or less
"If life is passing you by, downshift!"
11-21-2008, 11:30 PM | #15 | |
Moderator
7525
Rep 19,368
Yup.
And it also says, in fine print, "You f*cking idiot". |
11-24-2008, 04:19 PM | #16 | |
Rep 1,417
Really, it knows you then. Thats great!
11-24-2008, 07:03 PM | #17 |
Moderator
7525
Rep 19,368
11-24-2008, 09:04 PM | #18 |
Rep 12,445
Give the guy a break, shit. It's just a process that everyone should be informed of if they've never seen something like it before. You type your words with an air of superiority.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
11-25-2008, 12:02 AM | #19 | |
Rep 1,417
At this point its clear to me you have no idea how your DCT works, or that it is much closer to an Automatic than a Manual Select the gears transmission. NO Manual transmission has a Park feature at all. However you’re DCT does. In fact it works pretty much the same way any Auto trans. works, meaning it will hold your car in place with the park brake off while in Park mode. Once you move the selector to N or into say first gear, you must then use the Park break to hold the car from this point on when parking. Please refer to the post by kenwelch which has already mentioned this same thing, and for those who can’t read, somewhat like yourself it even has pictures. The fact that you must turn your car off to activate this Park function is not at all intuitive. By the way I also have read my owners manual for my 335i MT. Since it doesn’t have an automatic transmission I didn’t need to read that section. Even if I had chosen the auto. in my 335i. it still comes with a tried and true intuitive gear selector, including Park. Have a good day Richard Cranium. Red
11-25-2008, 06:19 AM | #20 | |
Moderator
7525
Rep 19,368
Oh and cheers. |
11-25-2008, 06:34 AM | #21 |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
S**t, I thought the + & - paddles on the steering wheel was for the calculator in iDrive and adding & substracting contacts in the phone book!
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
11-25-2008, 07:09 AM | #22 |
Moderator
7525
Rep 19,368
