11-03-2021, 10:20 PM | #1 |
Rep 21
F82 M4 swift springs and rubbing
Hey all, first post on the forum. I’m recently looking to lower my F82 m4 zcp on some swift springs. I’ve got 15mm rear spacers and my question is that will the combination of 15mm spacers and swift springs cause any rubbing?
Thank you in advance. |
11-03-2021, 10:22 PM | #2 |
Rep 783
Welcome to the forum! Are you still on the stock wheels/tires?
It's hard to know if you'll rub without knowing your current wheel/tire specs. I imagine you'll be fine with the OEM wheels.
Mosselman-powered M4 - 698/714 | 2.9 Whipple 2004 Cobra - 690/645 | Instagram
11-03-2021, 11:41 PM | #3 |
Rep 21
Thank you so much. Can't believe I forgot to mention that. I'm on stock 20 inch 666m wheels and stock PSS tires. Only thing done is the 15 mm spacers
11-04-2021, 11:45 AM | #5 |
Rep 21
Thank you very much. And since you are also on swift’s, do you have any problems with clearance and with scraping? I daily drive my m4 with the m performance front lip. I want the drop from the swift’s but I’m wondering if I need to go for eibachs for the clearance.
11-04-2021, 11:50 AM | #6 | |
Rep 783
When these things are lowered there's just not a ton of clearance but it's honestly totally fine to live with. Just requires being a little more careful than before.
11-04-2021, 06:29 PM | #7 |
Rep 21
Thanks a lot, I think I’ll be fine with scraping I am pretty used to slowing down and angling now
