      11-12-2021, 12:27 AM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3568
Apex Forged Wheels for BMW E82 1M| Performance Wheels for Street and Track
Fully Forged Performance Wheels for your BMW
Apex forged wheels represent the pinnacle of our offerings. These wheels are perfect for drivers looking for the ultimate in performance wheels both on and off track. These forged wheels are split into lines that offer unique characteristics to the enthusiast from strong and durable wheels built for punishment to lightweight designs optimized to give you every advantage possible. All of these wheels are available in chassis-specific widths and offsets developed specifically for your BMW.
      11-12-2021, 02:09 PM   #2
Expert@ApexWheels
3568
Forged Enduro Line
The Apex Enduro line consists of the strongest wheels we’ve ever made. These wheels feature our highest load rating and our strongest lip, allowing them to withstand abuse, lap after lap.
➡︎ 10K ton forged 6061-T6 aluminum
➡︎ Heavy-duty Enduro Spec inner lip
➡︎ Stiffer side-milled spokes
➡︎ Stronger 2100 lb. load rating
➡︎ Capless hub design to reduce weight
➡︎ 50% replacement program
➡︎ Independently tested and certified
VS-5RE
The VS-5RE is the forged Enduro version of our popular VS-5 design. These wheels bring serious strength and durability to the split 5 spoke design that BMW enthusiasts love and gives endurance racers and hardcore HDPE participants a wheel that focuses on longevity and consistency.
To view all of the VS-5RE fitments available for your BMW and order your set, Head over to our website via the link below or by clicking any of the images of these wheels.
Learn More
SM-10RE
The SM-10RE brings higher load ratings and measurable increases in strength and stiffness to our popular 10-spoke design. Initially available in fitments focused on modern M cars that are often tracked, these are perfect for wheel-to-wheel racing and focused HPDE sessions.
To view all of the SM-10RE fitments available for your BMW and order your set, Head over to our website via the link below or by clicking any of the images of these wheels.
Learn More
Our Strongest Wheels: Enduro Line Features
Most motorsport wheel designs prioritize reducing weight over increasing strength, but some applications require extra strength. High grip tires and lots of downforce put extra strain on wheels. Pair that with a faster driver and regular load ratings are not enough. Enduro line wheels are about 30% stronger than their RS counterparts.
Stiffer Spokes
Wheel stiffness matters but it gets overlooked and undiscussed. The redesigned spokes of the SM-10RE are about 20-25% stiffer than the Sprint Line version. Stiffer spokes help reduce camber loss, which reduces outer edge tire wear and improves feel and responsiveness.
Toughest Inner Lip
Introducing the Enduro Spec inner lip - our strongest ever. With 50% more reinforcement, these wheels are better protected against the harsh conditions found on (and off) track.
Reinforced Front Lip
We added extra material in the front lip for more durability so you can keep attacking those berms. You can easily spot the beefed up design of an Enduro lip vs. the lightweight lip on a Sprint Line wheel.
True Motorsport Blanks
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch to give us total control over the final product.
Side Milled Spokes
One of the most prominent features of our Enduro line wheels are the extra wide and deep side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. This allows our endurance wheels to be surprisingly light for their strength. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
Weight Optimized
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a significantly stronger wheel with a minimal weight penalty over their RS counterparts.
Independently Tested
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. Our Enduro Line wheels are independently tested by ITS at their Michigan facility following JWL standards but pushed to much higher loads and much longer durations.
Big Brake Clearance
From day one, Apex has been on a mission to build wheels that clear big brakes. These Enduro Line wheels are the product of everything we’ve developed over the past 15+ years. We utilize 3D scans to produce vehicle-specific spoke profiles, and our wheels feature an innovative high-clearance barrel design.
Deeper Concavity
Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between, each optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Paintless Knurled Beads
Whether it’s a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Paintless Barrel
To be as light as possible, and to reduce rotational inertia, we removed paint from the outer barrel. It’s only a fraction of a pound but it’s in an area that has the biggest impact on acceleration and deceleration, so it packs a bigger punch vs. the same weight savings near the center of the wheel. These small tweaks add up.
Capless Hub Design
We know most track day organizations ask for center caps to be removed. To further reduce weight that doesn’t directly correlate to strength, we incorporated a capless hub design on all Enduro Line wheels in our pursuit of Real Performance.
Built for Impact Sockets
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All Apex wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
Outer Lip Pocketing
A lot of areas get extra thick when the load rating is raised to 2100 lb. By CNC machining ‘pockets’ between each spoke, our Engineers were able to further reduce weight from an area that has a high impact on rotational inertia.
Laser-Engraved Specs
As track enthusiasts ourselves, we know how frustrating it is to locate and decipher wheel specs that have been hastily marked on a wheel or become unreadable over time. Our Enduro wheels have laser-engraved specs on the barrel, in plain sight, making them easy to find and read.
Your Fastest Lap is Calling!
Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. For those looking to shed as much weight as possible to improve lap times.
➡︎ Stronger Sprint™ spec inner lip
➡︎ Side-milled spokes for reduced weight
➡︎ Massive brake clearance
➡︎ Unmatched replacement program
➡︎ Lifetime structural warranty
Order Now
VS5-RS / EC-7RS / SM-10RS
Finishes
10K Tons Of Pressure
Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
Learn more about our true motorsport blanks.
Side-milled Spokes
One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
➡︎ 40-50% Wider
➡︎ 50-100% Deeper
Learn more about our wider and deeper side-milling.
A Stronger Lightweight Wheel
Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating. What’s the point of a lightweight wheel if it’s fragile?
Weight Optimized
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Tough Inner Lip
Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is 32% stronger.
Learn more about our Sprint™ spec inner lip.
Big Brake Clearance
From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
Deeper Concavity
Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Learn more about why our forged wheels have unpainted knurled beads.
Built for impact sockets
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
Additional Features
Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1 year finish warranty. Exchanges are fast, easy, and hassle-free.
APEX Wheel Replacement Program
Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage.
A Fitment For You
We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup.
The Weight is Over
Specifications for our Sprint™ Line designs
APEX Forged Sprint Line Wheel Gallery
VS-5RS Gallery
EC-7RS Gallery
SM-10RS Gallery
Order Now
Questions?
Call: 925-245-0773
Email: expert@apexwheels.com
Web: www.apexwheels.com
Hours: M-F 9a-5p PST
EC-7RS Details
VS-5RS Details
SM-10RS Details
      11-12-2021, 02:10 PM   #3
Expert@ApexWheels
3568
How APEX Engineers A Better Track Wheel
Crazy to think, but this is our first ever, in-depth video about any of our wheels.
Our engineering team put 2 years of hard work into our new Sprint Line and the forging dies that made them possible, so we were compelled to create a technical video that dives into the details. This video has a lot of great content our product descriptions don’t include. After watching, we’re confident you’ll truly appreciate why these features are so valuable.
If you're craving more content, this should quench your thirst.
While we've mentioned the program on these threads before, we wanted to share this freshly released video going through our Wheel Replacement Program with you all. This program is an under-appreciated part of buying APEX wheels that can be hugely valuable if you go off track midway through a lap or tackle the median of the street outside Cars & Coffee.
Our goal wasn't just to make pushing your car to the limit more affordable but also to reduce the chances of a bent wheel being sold on the aftermarket. All 4 wheel set orders are eligible for this program and while we hope you won’t have to use it, you’re covered if you do.
      11-12-2021, 02:20 PM   #4
PRTSB1M
Drives: AW3 1M
#shameless
      11-14-2021, 08:34 PM   #5
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Damn you. I have 6 track wheels I am happy with. Why do you tempt me like this????
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
      11-15-2021, 10:43 AM   #6
iDontRemember
Ding Dong!
iDontRemember's Avatar
Drives: AW 1M
Any plans to offer a forged version of the SM-10?
      11-18-2021, 02:40 PM   #7
Expert@ApexWheels
3568
Yes indeed! We can't get specific about the details just yet, but forged SM-10s are certainly on the way!
-Tom
      11-18-2021, 06:19 PM   #8
PRTSB1M
Drives: AW3 1M
We can we see on-car pics of VS-5RS 19” fitments?
      11-19-2021, 11:40 AM   #9
Expert@ApexWheels
3568
We have yet to do any photoshoots with the 19" versions of our new Sprint Line wheels. However, as soon as we have pictures, we will be sure to share them ASAP!
-Geirsen
      11-23-2021, 02:42 PM   #10
Expert@ApexWheels
3568
Paging BMW owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got!
If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
      11-30-2021, 01:13 PM   #11
Expert@ApexWheels
3568
Premium Finishes
Our New Sprint™ Line wheels are available in exclusive finishes right out of the gate. Brushed Clear gives a refined yet raw look that showcases our side milling and spoke profiles while fan-favorite Anthracite returns as a versatile option perfect for just about any color combination. Satin Black rounds out our finish lineup as the perfect understated option to provide contrast or complete a blacked-out look.
Which finish is your favorite?
Anthracite
Brushed Clear
Satin Black
Future Options
Beyond the custom forging blanks and weight optimization, our new forged production process is more flexible than ever. This allows us to include lower volume finishes and cater more to the needs of specific enthusiast markets that want a finish not yet included in our current lineup. Have a Satin Bronze or light Gold finish in mind? Something else we haven't even considered producing? Send us an email with the alternate finish you'd like to see become a reality along with your chassis and fitment details to experts@apexraceparts.com. Finishes with enough demand have a good chance of becoming a new standard option or being included in a limited run of wheels.
      12-08-2021, 12:29 PM   #12
Expert@ApexWheels
3568
When Function Meets Form
As wheel specialists, we understand that when it comes to reducing weight and increasing stiffness in wheel spokes, there is a big difference between functional and aesthetic side milling. Instead of milling a few negligible millimeters of depth just to look cool, our engineers optimized our new motorsport blanks to create narrower yet significantly deeper spokes with deeper side milling that is nearly 50mm wide on some wheels. The result is a stiffer “I” beam-spoke shape that also showcases a stunning aesthetic. If you haven't already, we recommend you read our technical write-up on our deeper and wider side-milling.
      12-10-2021, 06:19 PM   #13
Expert@ApexWheels
3568
With the release of our new forged Sprint Line wheels, we’ve had a few customers asking about how our upcoming EC-7RS visually compares to the classic forged EC-7R.
The overall design is obviously similar as this is our third iteration of the EC-7 design itself. Between the Classic Forged EC-7R and the new Sprint Line EC-7RS, the biggest visual difference will be seen in the spoke depth and side milling. Our new Sprint™ line of wheels features much deeper and wider side milling on the spokes versus our first generation of forged wheels. This improvement was made possible by our new motorsports blanks which allow us to create narrower yet significantly deeper spokes. The larger surface area on the side of each spoke allows us to take more material out. Doing so creates a much stiffer “I” beam or c-channel spoke shape. Visually that means the EC-7RS has deeper but thinner spokes with deeper side channels. The spokes of the EC-7RS also connect to the outer lip of the wheel, unlike our older EC-7R. This further reinforces the outer lip.
The inner lip won’t be easily seen when the wheels are mounted but has been updated with a unique C-channel as a result of a full redesign for additional strength in this crucial area. The inner barrel now includes laser etching to make specification identification a breeze and is a completely redesigned profile for even better brake clearance.
Porsche-spec etching shown
Ultimately, these changes were driven by our goal of improving our product offerings in a meaningful way. Beyond expanding the width and diameter offerings to fitments we’ve never before produced, these fundamental changes have resulted in higher performance wheels with an aesthetic that we are extremely excited about. 5x120 EC-7RS BMW fitments will be incoming with Group Buys of their own in the next few months. Stay tuned!
      12-10-2021, 08:03 PM   #14
PRTSB1M
Drives: AW3 1M
When does pre-order for 19 inch wheels open?
      12-15-2021, 01:03 PM   #15
Expert@ApexWheels
3568
We don't have a concrete start date for the 19" Group Buy arrival dates yet, but with many of those wheels arriving in March for both designs, we expect to begin the Group Buy process sometime in mid-January. Stay tuned for more details!
-Tom
      12-15-2021, 03:02 PM   #16
Expert@ApexWheels
3568
Get To Know Our 50% Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, or a club racer pushing the limit for a podium finish, mistakes happen, and parts can get damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our goal was to make replacing a damaged wheel with a brand-new one much more appealing than ignoring the problem or performing any questionable and compromising repairs. This program will also help keep damaged wheels from being passed on to unsuspecting enthusiasts via the secondhand market.
Discounted replacements are ideal for customers who accidentally damage their wheels with curb rash, bends or dings from potholes, berms, road debris, and off-track excursions. Complete destruction of a wheel from serious accidents also qualify, including tire wall or barrier impacts, contact with other racers, or any accidents resulting in a total loss.
All pledged members that participate in this Group Buy would be eligible for this replacement program. For more details, be sure to visit our website here.
      12-15-2021, 11:49 PM   #17
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
That picture makes me cringe!
I have both front inner barrels scored on my M2cs with 2NH brake package thanks to my local DOT doing a chipseal on my street and all routes to my neighborhood. Ug. The chip stones are the perfect size and coarseness to lodge between the caliper and the barrel. Any idea how much clearance your 19's will provide relative to the OEM BMW 763M's?
      12-17-2021, 01:57 PM   #18
Expert@ApexWheels
3568
We don't have measured dimensions of the 763M inner barrel to compare against our Sprint Line VS-5RS wheels, but our Flow Formed 19" wheels for the M2 competition in our EC-7 and SM-10 designs easily clear the 400mm 2NH/M2 CS brakes with room to spare for debris. These same wheels with a similar inner barrel design also clear the 410mm CCB packages on the F8X M3 and M4 easily and our Sprint Line wheels will have inner barrels with even more inner clearance than the Flow Formed wheels we currently offer so you should be in good shape even with continued road work.
-Tom
      12-17-2021, 01:58 PM   #19
Expert@ApexWheels
3568
What are Motorsport Blanks?
Join Yo and Eddy(APEX Founder) to learn how to spot wheels that may have been limited during the engineering phase to offer motorsport rich features and find out why we worked so hard to engineer new motorsport blanks to create our new fully forged Sprint Line wheels.
It was a long road to this launch, but now that we're here you all can look forward to benefiting from the features we can offer on the Sprint Line and future lines of forged wheels to come!
      12-21-2021, 04:48 PM   #20
Expert@ApexWheels
3568
VS-5RS Profile Comparison
With so many new fitments available in our all new VS-5RS design, we’ve gotten a few requests to showcase the various profiles available. While all of our Sprint™ Line designs have their profile optimized on a per-application basis, we’ve categorized these wheels into 4 Profiles based on their depth for easy identification. Our investment in the Motorsport Blanks mentioned in the post above has allowed us to make Profile 4 wheels for the first time via additional material available to our engineers during the design phase of this project. These are the most concave wheels we’ve ever made and they help round out the Sprint™ Line which stretches from narrower high offset fitments for Porsche and non-M BMW chassis to wider low offset wheels for Domestic and widebody applications.
Profile 1:
Profile 2:
Profile 3:
Profile 4:
View the full list of inbound fitments and their specifications including Face Profile in the OP of this thread or on our website here:
VS-5RS
EC-7RS
      12-23-2021, 06:46 PM   #21
Expert@ApexWheels
3568
We thought we’d share some photos and a video of this 1M on our new VS-5RS wheels. With a set of square 18x10 ET25 wheels and suspension architecture and other parts plucked straight from the E9X M3, we can’t imagine a better way to tear up the canyons.
Full Feature Thread
Technical article
All APEX Sprint Line forged wheels feature unpainted knurled beads. The problem with knurling is that it varies by manufacturer in design and effectiveness. Whether it’s a day at the track or months of street driving, repeated hard braking can make a tire slip on the bead seat and go out of balance, causing vibration.
Maintaining the effectiveness of our knurling was at the forefront of our minds when developing our new line of forged wheels, which is why there’s no paint covering the bead area. Instead of adding basic knurling with paint over it just to check that feature box from a marketing perspective, our engineers optimized the functionality of our knurled beads by leaving them unpainted to ensure they have a more effective “tooth” to bite into a tire’s bead. It is a more expensive process, but it is one of many details that results in a better wheel. To learn more, be sure to read our technical write-up below.
Paco1M101.50
      12-31-2021, 06:58 PM   #22
Expert@ApexWheels
3568
As our initial 18" Group Buy draws to a close, we thought we'd share some shots of a track-prepped e92 M3 on our VS-5RS wheels at Thunderhill Raceway.
Full Feature Thread
1addicts
