02-04-2022, 09:03 AM | #1 |
Rep 110
1 weeks M3 ownership, here are my questions
I picked up my M3 last week and have some questions!
More to understand if my car is ok or not! - Suspension seems stiff in all modes, is there hardley any diffrence between the settings? - Sometimes i hear a slight knock from the back end, reminds me of when I used to drive lowered cars. I have called BMW to look at it just to be safe but have you guys had this? - Road noise seems...noisey! Not on run flats so its not that, is it just because im not used to it? - Stones kicking up seems to be another thing ive notices, a lot of stones going in the arches. Anyway put my mind at ease! For ref i have come from an F32 335d Thanks! |
02-04-2022, 09:31 AM | #2 |
Rep 32
- Suspension seems stiff in all modes, is there hardley any diffrence between the settings? What tyres are you running? I think the PS4S offer slightly better ride comfort but cant say i think its particularly harsh and I've come from a G30 with RF tyres
- Sometimes i hear a slight knock from the back end, reminds me of when I used to drive lowered cars. I have called BMW to look at it just to be safe but have you guys had this? Cant help with this, sorry. - Road noise seems...noisey! Not on run flats so its not that, is it just because im not used to it? Same Q on tyres - the MPS4S are quieter than the SS - Stones kicking up seems to be another thing ive notices, a lot of stones going in the arches. look for F80 Carbon mudflaps or TLG mudflaps (made by a member if i remember right). Common problem due to design - best to get some flaps to protect the paint
Current: G30 530e M Sport
Later this year: F80 M3, spec TBD |
02-04-2022, 09:32 AM | #3 |
///M Powered for Life
11502
Rep 10,334
Hello, welcome to the forum
You're in a full fat M car. Comfort is not the priority. The suspension is relatively stiff. There is a difference in all the modes, but it isn't night and day. Low profile tires with sporty intentions have stiff sidewalls. No idea about the knock. It could be the diff acting up? Road noise: full fat M car, less sound deadening than a normal car |
G35POPPEDMYCHERRY4998.50 |
02-04-2022, 09:39 AM | #4 |
Rep 110
Sounds like I need to man up. I thought this might be the case
Will look for mud flaps as well. Running new PS4's Knocking noise I will see what BMW come back to me with. Its not massively loud, and only occasionally. |
02-04-2022, 09:42 AM | #5 |
11502
Rep 10,334
You haven't said which wheels you are on. M3s came with 18, 19 and 20 from the factory. If you have 19 or 20 you will gain some impact harshness reduction by getting the 18" wheels.
02-04-2022, 09:59 AM | #7 |
11502
Rep 10,334
Well, consider moving to 18s if you have normal (non-CCB) brakes, it will make a slight difference
02-04-2022, 01:55 PM | #9 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
Knock in back in...no idea. Broken suspension part? Road Noise is normal for a performance coupe. It's actually significantly quieter than my old FRS which had like no sound deadening. Get mudflaps for stone chips or PPF in high chip areas.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
02-04-2022, 02:40 PM | #10 |
Rep 895
I have these on mine...they work great and look good too!
https://automotivepassion.net/produc...age-ap-design/ |
02-04-2022, 02:50 PM | #11 |
Rep 21
The knock you are referring to may be clunking from the diff area? Does it mainly happen when coming on and off throttle? If so that is fairly normal for these cars assuming it is not overly excessive or loud. But it is not a bad idea to have bmw check it.
spidy512502.00 |
02-04-2022, 03:33 PM | #12 |
Rep 1,467
Drives: 2023 G81 M3 Touring
I notice a decent difference in the suspension modes on my M4 (437M with PS4S), but it’s not as pronounced as on my G01 X3 with adaptive suspension (20-inch wheels with factory P ZEROs).
Road noise can be down to the tyres you’re running and the road surface. Been pleased with the NVH in my new to me M4 with the PS4S tyres. Stones kicking up can also be related to the tyres you’re running. Stickier tyres, more stones are picked up and flung about. |
02-04-2022, 04:08 PM | #13 |
Rep 1,289
Dry sump flat six
02-04-2022, 07:18 PM | #14 | |
Rep 548
spidy512502.00 |
02-04-2022, 07:55 PM | #15 | |
/M Enthusiast
1603
Rep 1,619
Let’s start fresh with what year and what package your M3 is, also new or used.
Then we can start to speculate. Quote:
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
02-04-2022, 10:11 PM | #17 | |
Rep 696
Drives: 2015 f80 M3
I bought mine with a torn rear diff busing. It had a soft "clunk" when accelerating or decelerating. You can crawl under the back of the car and visualize it. If you search around here you will find many threads ref'ing this problem. And pics. I see many posts on the adjustable suspension not feeling a difference. I most def feel a difference with my car. In comfot is wallows around and is much more loose when getting on it. Sport and Sport+ are noticably stiffer (to me). So not sure what to say other than maybe you need to get used to it? Also, fwiw, if there is a loss of signal to the shocks, they default to an absurdly stiff setting. I doubt that is your isssue, but something to know going forward. In this mode, the car is crazy crashy over anything. Congrats on the ride! Good luck with all of it... josh |
02-04-2022, 10:17 PM | #18 | ||
Rep 548
spidy512502.00 |
02-05-2022, 07:14 AM | #19 |
Rep 834
2016 M3 6MT, Yas Marina Blue/Silverstone - Sold
2023 X3M Competition, Brooklyn Grey |
02-05-2022, 11:22 AM | #20 | |
Rep 696
Drives: 2015 f80 M3
I forgot to mention that. I did get thew turner with ECS/PF bushings. The plate make a big difference in the rear end stability. Which these cars need desperately. josh |
02-05-2022, 12:41 PM | #21 |
Rep 1,009
Are you located in a cold climate? Running summer tires when it’s regularly 50F degree or below makes a huge difference in comfort. If you want less noise and more comfort you need to sacrifice tire performance during the colder months. Consider getting all season tires if it bothers you that much.
spidy512502.00 |
02-06-2022, 09:13 AM | #22 |
Rep 30
I've heard it said here that the F80 has more "normal" noises than most other cars, and I agree with this. For reference I've owned mine for about 10 months and although I wouldn't say I was concerned about the noises I was aware of them. Mine's 6MT and if I'm fast off the throttle at medium RPMs and slow with the clutch in 1st I'll get the clunking from the rear. I plan to upgrade the diff bushings at some point but I don't think it's anything to be worried about.
The ride is busy in this car, esp on the 20" 666 wheels and with these crap MD roads. I'm on 18" wheels with Blizzaks for winter, which improves the ride significantly. But, as others have said: harsher ride comes with the territory. I do notice a difference when switching from comfort to sport or sport+ (which I never use on the street), so that might be something to look into if you're not feeling any difference at all. Congrats on the new car! |
spidy512502.00 |
