02-05-2022, 06:26 PM | #1 |
Rep 8,077
Drives: 11 E90 M3 Individual
BMWCCA is back at COTA - Jun 10-12
Not sure if it's been advertised that well so far but BMWCCA is back at COTA. Not a joint event with PCA...but it's a BMWCCA event.
http://msreg.com/BMWCCA-COTA-2022
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue Last edited by bigjae1976; 02-06-2022 at 12:05 PM.. |
02-12-2022, 05:01 PM | #4 | |
Rep 8,077
I've ran my E90 M3 without issue. My E46 would run really hot when it was closer to stock.
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
02-15-2022, 08:53 AM | #5 | |
BimmerPost Supporting Vendor
4736
Rep 2,554
do88 coolers can also clear this right up Do make sure your brakes are up for it if you go - COTA is also hard on brakes.
02-25-2022, 05:26 PM | #6 |
Rep 8,077
Really need to check the whole car carefully. You'll see higher lateral loads since the surface is grippier than most. I see 1.3gs and 1.4gs more often. I've even peaked at 1.6gs. It's harder on suspensions, electronics, and the motor.
02-25-2022, 08:08 PM | #7 |
Rep 169
Why June? Figured BMWCCA could do better (i.e. shoulder or winter months)...
'11 e92 M3 ZCP Lemans/Nappa DCT
'04 e46 M3 AW/Nappa 6-Spd '11 e90 M3 ZCP SG/Nappa 6-Spd Stripper (sold) |
03-03-2022, 09:19 AM | #8 |
4736
Rep 2,554
Should always check the whole car carefully before going on any track...
