02-22-2022, 09:13 PM | #1 |
Rep 528
E92 M3 2008
I have E92 2008 M3 that says misfire cylinder 1-2-3-4-5-6-7-8 . I have changed all coils and spark plug on all cylinders . With BMW ones . Now it says Misfire on cylinder 7 . Anyone had this problem ? I ordered a used fuel filter im waiting for . Anything else to check ? Your help is greatly appreciated. Thanks it's my sons car .
Build by (PSI) 2019 M2C , BC suspension , BC wheels , DP , Vorsteiner trunk lip , Diffuser , Side Skirts , IND reflector kit , Rw carbón hood , DME Tuned !
E90 M3 Supercharged |
02-22-2022, 09:49 PM | #2 |
Rep 428
Have you done any other work recently? Did you change plugs and coils before or after this problem?
What scanning software do you have access to? I’d start with checking voltages at the coils. I always mention this because I had a bad ground that caused misfires. There are lots of possibilities here, post as much info as possible. |
02-22-2022, 09:52 PM | #3 | ||
Rep 528
I changed all Coils and Spark plugs the code says misfire on cylinder 7 . I changed it before .
fs34411.50 |
02-22-2022, 09:58 PM | #4 |
Rep 428
Dumb question, did you double check all connections from coils to engine harness? Tried reseating coils? Swapping coils or plugs from 7 to somewhere else?
My misfire was 7, it was a bad ground but unless you did actuators or something in the valley, I don't think you'd have the same issue I had which was from someone who replaced TAs and didn't bolt the engine harness/grounds back down. It was found with some voltage monitor in ISTA. No idea what your issue is, but I'd start with where I last touched the car and work back from there. If it's misfiring after you worked on it, best to start there. |
DrFerry6731.50 |
02-22-2022, 10:01 PM | #5 | |
Rep 528
02-23-2022, 12:23 AM | #6 |
Rep 1,128
Fuel injectors can go bad and cause bore scoring,low compression or hydrolock. Get a compression and leakdown test done.
02-23-2022, 06:46 AM | #7 |
Rep 528
I will check that out today .
Drifter2090912.50 |
02-23-2022, 01:36 PM | #8 |
Rep 611
Drives: 2013 M3 coupe' 6mt
Broken valve springs are a known problem on S65 engine.
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
DrFerry6731.50 ///M Power-Belgium64252.50 |
02-23-2022, 02:22 PM | #9 | |
Rep 436
Arsenal F.C. - Gooner 4 Life
02-23-2022, 03:14 PM | #11 |
Rep 428
When I had my issue this is what the original diagnosis was. I had tried everything swapping coils, injectors, plugs. Gave up and had it towed to BMW. After 6 plus hours of diagnosis they found nothing. The tech then said he was putting it back together to start over and re check. That’s when he found a missing nut on the engine harness, which led to a bad ground.
Went through the emotional roller coaster of thinking I needed a $7500 valve job to a $1 nut. Glad that is over but I learned a lot. Hope it’s something simple like this for the OP. Last edited by fs34; 02-23-2022 at 04:08 PM.. |
Drifter2090912.50 DrFerry6731.50 |
02-25-2022, 12:22 PM | #12 | |
Rep 528
DrFerry6731.50 |
02-25-2022, 12:36 PM | #13 | |
Rep 61
02-26-2022, 08:47 AM | #14 | |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
