05-18-2022, 05:49 PM | #1 |
Rep 173
666M Wheel and Caliper (Help and How to)
Ok I think this wheel and caliper color combo stands out so beautifully on this car but it is a pain in the a$$ to keep clean, both the caliper and the wheels. As soon as i clean them or wash the car and drive off the dirt and grime come back as expected.
My question is, Is there an an easier proven method to say to be able to remove the dirt easily by having a coating put on them?? Also whats the best method to clean this type mesh wheel easily?? I keep jacking up my fingers having to fish in and out every nook and cranny gets annoying after awhile. Any help is appreciated. BTW ive tried polishing the wheels (on the car) to see if it would help make the dirt fall\come off easier but didnt seem to help much. I even have the small brushes to get in the bolt holes but those angles crevices are a bi%$@. Thanks in advance. |
05-18-2022, 06:00 PM | #2 |
Rep 356
Get akebono brake pads first of all huge improvement. Then after first cleaning get spray on wheel cleaner / iron x spray each wheel before wash. Rinse wheel with pressure washer and you'll be 90% clean. I usually just dry them off and call it a day.
05-18-2022, 06:03 PM | #3 | |
Racecar Driver
1312
Rep 1,989
Drives: BMW M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
PhatLyfe985.00 |
05-18-2022, 07:36 PM | #4 |
Rep 641
I took all four wheels off and cleaned them thoroughly and then did 3 coats of ceramic coating. My silver 666s stay almost completely clean now for really long periods. Also very east to wipe clean with a good microfiber towel and there is almost 0 brake dust that accumulates.
05-18-2022, 08:09 PM | #5 |
/M Enthusiast
1603
Rep 1,619
I gave up, I’ve got track rubber still stuck on both car’s rims and they are dirty.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
05-19-2022, 05:52 PM | #6 | |
Rep 173
Ill have to look into the Akebonos but in the meantime ill probably have to get a bottle of that Iron X and see. I have the Sonax wheel cleaner someone else recommended but i was expecting more. Thanks again for suggetion. |
05-19-2022, 05:54 PM | #7 | |
Rep 173
I think im leaning more towards this option after trying spray on cleaners and the like. How much did it cost to ceramic coat all wheels and calipers?? And how long is that supposed to last approx under the heat and stress?? Thanks again. |
05-19-2022, 10:05 PM | #9 |
///M SubDriver
1846
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
Another shout out for the Akebono Euro pads due to their excellent braking performance and very low dusting. As far as wheel cleaners go, I would not use iron removers like Iron-X on a routine basis. Save those for the occasional deep wheel cleaning. For very effective, including cost effective, routine wheel/tire cleaning, I would recommend P&S Brake Buster or Extra Tough Wheel & Tire cleaner. I have both of these and they come highly recommended in the car detailing community (especially P&S Brake Buster).
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
05-20-2022, 06:47 AM | #10 |
Rep 1,988
Akebono++++++++
Took an hour to put all four in by myself. It's a night and day difference. I should be an akebono sales rep at this point.
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO 2016 340i xDrive : AW/CR (sold) |
05-20-2022, 08:16 AM | #11 |
Rep 276
Like Jmciver, I also use P & S Brake Buster Total Wheel Cleaner. Spray all four wheels, and then come back to the first wheel I sprayed. I then hit the wheel w/a wheel brush (nothing crazy, just to knock any stubborn build up) finish up by rinsing off w/a pressure washer. Move to the next wheel, and repeat.
05-20-2022, 08:23 AM | #12 |
Rep 98
05-20-2022, 08:54 AM | #13 | |
Rep 1,988
05-21-2022, 04:50 AM | #14 |
Rep 1,371
Here's what works well for me. My brake rotors are steel and the rotors/ brake shields always look brand new...
1) Spray wheels AND brakes with Sonax 2) Lightly agitate with a wheel brush 3) high pressure rinse 4) Immediately drive the car around the block before the steel rotors start to rust. Very limited in time here... 5) Wipe down wheels with microfiber cloth. |
swagon13567.50 |
05-21-2022, 06:13 AM | #15 | |
Rep 8,185
Also, get your wheels ceramic coated. Then just a simple pre-wash foam that you use for bodywork, followed by pressure wash, will get most of the dirt off. Then clean the intricate areas with a brush and MF towel. One wheel incl. wheel arch takes me 3 mins. And further, not caring about brake dust as much helps a ton.
05-21-2022, 01:50 PM | #16 | |
Rep 356
05-21-2022, 09:49 PM | #17 |
///M SubDriver
1846
Rep 2,787
Sure it is safe for your car’s paint (and painted wheels) for occasional paint decontamination. I use Iron-X (or actually P&S Iron Remover as it is basically the same stuff but cheaper) for that purpose 2-3 times a year on my car’s paint and wheels - max. But for routine washes, every 1-2 weeks, I would not want to use it. But your car so your choice obviously…
05-22-2022, 12:15 AM | #18 | |
Rep 3,786
05-22-2022, 01:32 AM | #19 | |
Rep 356
05-22-2022, 06:18 AM | #20 | ||
///M SubDriver
1846
Rep 2,787
05-22-2022, 04:42 PM | #21 |
///M SubDriver
1846
Rep 2,787
One other tip to consider for you guys for cleaning and helping to keep your wheels clean…. While ceramic coating your wheels is clearly a very good option to help keep them clean and make cleaning them easier (the wheels on my M3 are ceramic coated), Gyeon Wet Coat is a good short term protection alternative. I use this primarily on my wife's X3 and my X7 (and I use it as extra protection on my M3 wheels as well).
To use it is very simple. Clean and rinse your wheels using the method of your choice. While your wheels are still wet, spray it on (a little goes a long way) then immediately rinse off. Dry your wheels as you normally would (a leaf blower works well). If you don't have any form of protection already on your wheels, your wheels will get an instant hydrophobic (and gloss) boost of protection. It is claimed to last 2-3 months, but the best I have seen is 3-4 weeks (on a daily driver that is parked outside). But that still makes the benefit worth it to me. There are quite a few YouTube videos on using the stuff for this purpose as it has been around a while.
OutoftheBlueM243.50 |
05-31-2022, 07:52 PM | #22 | |
Rep 173
Thanks I ordered a bottle off amazon. I have yet to try it though wanted to make sure i understood how its used first which based on what you said sounds simple enough. I will try it next wash. Bottle was smaller than I thought it would be though. |
