05-28-2022, 11:10 AM | #1 |
Rep 41
Another gas question
I'm going to flash my ecu and trying to decide between 91 ots or 93 ots. I'm in California where 91 is the highest octane available. I live a couple blocks away from a station with 100 octane. I know mixing in 3.5 100 octane with 91 octane will equal about 93 octane. Should I go with the 91 ots and utilize the 91 gas for daily driving or flash 93 and mix 100 with 91 every fill up?
05-28-2022, 05:59 PM | #6 |
Rep 628
Bootmod3 OTS multimap.
McBobby Jr212.00 Bjammin1.50 |
05-28-2022, 06:45 PM | #7 |
Rep 3,645
better off with the 91 map.
you could run the 93 map and still put 91 in it just to get home as long as you're not doing full throttle pulls. then put the 93 in it once you get home. honestly though the performance difference between 2 octane points isn't that huge to be worth it |
Bjammin1.50 |
05-28-2022, 07:02 PM | #8 |
Rep 577
This would be your best choice, as with the Multimap you'll be able to switch maps on the fly so in the case you can't get your 93 Octane, you can run the 91ACN Map or the 91 Map. As for getting your 91 Octane up to 93 Octane for the 93 Map. An Octane Booster, or a few gallons of 100 Octane at the pump will work well. A couple gallons of E85 will work great, and if you want more power, an E30 map would work even better. This is assuming you have 100 Octane or E85 at the same pump where your 91 Octane is.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
Bjammin1.50 |
06-01-2022, 12:42 AM | #10 |
Rep 41
06-01-2022, 01:26 AM | #11 | |
Rep 268
OP just run the 91 tune. Why would you want to risk detonation for the very little bit of power? Pretty sure all of those maps override the safety parameters.. |
Bjammin1.50 |
06-01-2022, 11:35 AM | #12 |
Rep 41
That's true, it's my daily driver so I don't need so much extra power. I'll do multi map if I ever track it in the future. Thanks everyone for your help, much appreciated.
06-01-2022, 01:23 PM | #13 |
Rep 56
I had an AMG C63S Coupe that had catless DP and a tune.
I had a 100 octane tune for when I went to the track or 1/2 mile racing. But my 91 tune map was so aggressive that it was more like a 93 map and I used to throw 3-4 gallons of 100 octane in with each fill up (back before gas was so high) and the car ran great. For going out of town (away from my 100 octane station) I could throw a bottle of Torco octane booster in the car if needed and this worked well. It is nice to have 100 octane right around the corner like I did also...I say go for it and you will figure out the fuel part and enjoy the added power.
2020 M4 CS - Black Sapphire Metallic
06-02-2022, 12:43 AM | #15 | ||
Rep 3,729
You can add 2 gallons of E85 then fill the rest up with ACN91. That will get you to E19 and 92.1 octane approximately. You should be fine with that setup on either stage 1 or stage 2 91 maps.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
06-06-2022, 07:15 PM | #16 |
Rep 577
Also for Boostane/Octane related stuff, use this thread for reference.
BOOSTane to bring CA 91 gas to 93 https://f80.bimmerpost.com/forums/sh....php?t=1642951
current
06-06-2022, 11:08 PM | #17 |
Car Enthusiast
480
Rep 1,132
Would care to elaborate on the issues I don't know yet, but you claim I probably do?
06-07-2022, 09:19 AM | #18 | |
Rep 5,188
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
