05-29-2022, 11:40 AM | #1 |
Rep 193
Ground Control Camber Plate binding?
Hi Guys I just finished installing these plates. Customer service from GC is non-existent and there isn't too much info online.
I'm getting this nasty binding sound from the passenger side only. I have installed both sides exactly the same. any ideas on what this is from? https://youtube.com/shorts/dghO09xSMr8?feature=share |
05-31-2022, 03:59 PM | #4 |
Rep 3,412
Get a set of Torrington bearings for the spring perch.
https://www.bimmerworld.com/ssearch....ery=Torrington
Not a Doctor, those are just my initials.
Hivand_M138.00 |
06-04-2022, 10:22 AM | #5 |
Rep 193
Thanks guys. I ended up taking everything apart again. The bearings were not lined up and honestly I can't believe how little grease they had in there. Packed the bearings with grease, lined up all the bearings and there is absolutely no noise anymore.
06-04-2022, 10:41 AM | #6 | |
Rep 3,412
Also, I'd still recommend getting the Torrington bearings to eliminate spring bind. Once weighted it would rotate as nicely on the perch as it does on the lift.
Davisca4552207.50 |
06-04-2022, 04:44 PM | #7 |
Rep 8,077
Drives: 11 E90 M3 Individual
I had GC plates. The bearing requires servicing which is a PIA.
Vorshlag is the best solution.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
Davisca4552207.50 Hivand_M138.00 |
06-04-2022, 07:05 PM | #8 |
Rep 4,178
Got a couple guys here just installed new GC plates and complaining about noise. Meanwhile my used Vorshlag plates are quiet as a church mouse.
Davisca4552207.50 |
06-05-2022, 10:16 AM | #9 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Installed GC camber plates in 2018 and never serviced and still completely silent.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
Hivand_M138.00 |
06-05-2022, 01:40 PM | #10 |
Rep 193
In all the reading i've done it seems it's 50/50 with both Vorshlag and GC plates that make noise or don't. I feel like it all comes down to the install and not the product. The people that got GC plates on the first time and made no noise, maybe their bearings were lined up perfectly and packed with grease from the moment they were shipped out? Idk.. mine were brand new straight from GC and they looked like the picture above when taken apart. This was a max 2-3 hr job that took me a total of maybe 16 hours.
I would say it was well worth it and I wouldn't drive this car with any less camber again. I would also like to add again that GC customer service was garbage so if you care about that maybe give your money to Vorshlag although I have no experience with them. |
06-05-2022, 01:46 PM | #11 |
Rep 193
Here's 1 of many reasons why it took forever for the install. The OEM alignment pins are a bit smaller than GC's alignment pins. For a few hours I was trying to figure out why the plates were not sitting flush in the car. (I know I could've gone without the pins but with the pins you'd have a more accurate reading of where the camber is when switching from street and track)
06-05-2022, 01:52 PM | #12 |
Rep 193
And lastly, here is why the bearings were not in place. They were zip tied together for shipping obviously. The black section is supposed to sit flush inside of the yellow portion, that is where the bearings are. For someone DIYing this, they wouldn't think to open that and check it out first but to keep it all together when removing the zip ties for install.
I'm not talking smack about the product but maybe there is someone else that will DIY this and it might help as there is no guide online for this. The plates are well built and I have 0 complaints now but I believe the noise comes from install errors and it's little things like this to look out for. |
06-05-2022, 04:12 PM | #14 |
Rep 8,077
Vorshlag uses a large spherical bearing instead of the roller bearing that GC uses. The roller bearing isn't sealed well either. I guess both are subject to the same contamination from dust and dirt but Vorshlag doesn't market theirs as street use.
Hivand_M138.00 |
06-05-2022, 05:38 PM | #15 |
Rep 4,178
06-05-2022, 11:35 PM | #16 |
Rep 193
Might want to take it apart and give it a clean/re-grease. Also adding the spring thrust washers DRLane mentioned wouldn't be a bad idea while there.
06-06-2022, 01:49 PM | #17 | |
Rep 361
Hivand_M138.00 |
06-06-2022, 02:05 PM | #18 | ||
Rep 193
What I did was remove the strut brace and screw in the pin from the top after I got everything lined up. I was scared I'd dent the strut tower trying to get it to pop in and I did not want to drill anything. Extra work but gave a peace of mind. |
