06-17-2022, 06:46 PM | #1 |
Rep 8
Can someone give me advice? Is the timing and camshaft installation position correct
Can someone give me advice? Is the timing and camshaft installation position correct?
06-17-2022, 08:59 PM | #2 |
BimmerPost Supporting Vendor
3769
Rep 2,912
Drives: 2011 E93 M3
There's no way for anyone to answer this from pictures. The difference in camshaft degrees between running properly and not starting is precise and not something you can assess by looking at pictures of the top end.
You need a cam timing tools for S65, lock the crank at #1 TDC, then perform the process for checking timing as outlined in TIS. |
06-18-2022, 01:52 PM | #3 |
Rep 2,071
and for the love of (insert deity here) DO NOT put it back together without checking the timing with an actual, OEM timing tool, or not starting could be the least of your worries.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
