06-21-2022, 06:27 PM | #1 |
Rep 524
Recommendation for polarize front windshield
As the title reads, I'm looking for the best option to replace my front windshield. I would like to have a polarized version, and I'm not sure if BMW makes one or if there's a third-party recommendation. I know Safelite has one. I had it on my 5 series, and it didn't look horrible. I'm just wondering what others have gone with.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
06-21-2022, 06:49 PM | #2 |
Rep 954
Not sure about polarized, but the PO said he put some kind of anti-UV windshield on my car. It is not darkened and looks more or less normal, but when I wear my polarized sun glasses it does make things look a bit odd. Blacks kinda look green and whites kinda look pink. But less UV damage is worth it. Not that my car sits in the sun much, lol.
Bmwdoubles_194.00 |
06-21-2022, 10:37 PM | #3 | |
Rep 1,128
Bmwdoubles_194.00 |
06-22-2022, 01:41 PM | #4 |
Rep 865
I had the Safelite solarized option installed.
It really works well as a heat barrier. So much so, that the heat passing thru the side glass has become much more noticeable. Now I need to have the side glass addressed to even things out. Has a purple tint that bugged me for about 7 minutes…
Chris, 2008 E92 |
9
Bmwdoubles_194.00 derbo3611.50 Battle162.50 B8bydesign689.00 Frostynorth432.50 wyatth3551.50 LakeHouseSurf43.50 mikepale6039.50 CurbBender'9071.50 |
06-22-2022, 07:19 PM | #5 | |
Rep 524
Davisca4552207.50 |
06-22-2022, 07:45 PM | #6 |
Derbo Tuning
3612
Rep 3,027
European BMW offered this on the E9x.
This is called Climate Comfort windshield by BMW. Vehicle order for climate comfort is S358A. Safelite does also offer a Saint Gobain (OEM) Solarized windshield as well. Davisca455 got an aftermarket brand but still just as effective. -Purple hue is a high UV rejection film in the windshield. -I dig the purple lol -It can block some frequencies from transferring; in our area our toll transponders will not work unless in the rear view mirror mount area where the film is not present. -It's heat rejection is on par to high end tint with high Total solar energy rejection (TSER). Good luck! I regret not trying to order it when my windshield cracked.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
06-22-2022, 08:44 PM | #7 | |
Rep 2,197
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
06-22-2022, 09:23 PM | #9 |
Rep 865
This is for the "aftermarket" one.
The Safelite website didn't show an option for the Saint Gobain version, so you'll likely need to make a phone call to specify that version.
Chris, 2008 E92 |
Bmwdoubles_194.00 |
06-22-2022, 09:34 PM | #10 |
Rep 303
My understanding of the polarization of light means that a truly polarized windshield will reduce the light by 50% ie the windshield will appear darker. To test for true polarization, get a pair of polarized sunglasses inside the car and rotate them through at least 180 degrees while looking through them. The windshield should appear totally black at some point in the rotation. If the windshield goes through a cycle of just lightening and darkening (without going black) then the polarization of the windshield is partial.
Baba Louey |
byroncheung179.00 |
06-22-2022, 10:28 PM | #11 | |
Derbo Tuning
3612
Rep 3,027
There is a high UV absorbing/reflecting film in between the layers of glass. It is designed to reduce UV to passing through the windshield. It shouldn't drop light by 50%. Maybe a little, but not that significant. Saint Gobain ClimaCoat webpage: https://www.saint-gobain-sekurit.com...ity/climacoatr
IG:ruhrohz_m3
byroncheung179.00 |
06-22-2022, 10:32 PM | #12 | |
Derbo Tuning
3612
Rep 3,027
Another check, the rear view mirror mount area does not have a film to allow for transponders to be mounted. You will be able to see a distinct film line where it ends.
IG:ruhrohz_m3
Davisca4552207.50 |
06-22-2022, 10:58 PM | #13 |
Rep 524
This thread has some good pics of the European Climate Comfort version and that has the BMW logo on the window. I think that adds value to the car.
https://www.e90post.com/forums/showthread.php?t=1718446 Though that Saint Gobain Swedish version is pretty dope too.
derbo3611.50 mikepale6039.50 |
06-22-2022, 11:35 PM | #14 | |
Derbo Tuning
3612
Rep 3,027
That little logo with the temp stick is Solar Coat! If you visit realoem.com can you find the part numbers for coupe and sedan in the euro market catalog. They have S358A = yes The part number I have for E90 is 51317203857 . But I think Safelite actually carries Saint Gobain as well as the chinese stuff. You might need to call them to get the Saint Gobain though.
IG:ruhrohz_m3
06-23-2022, 10:00 AM | #15 | |
Rep 303
Baba Louey |
derbo3611.50 |
06-23-2022, 10:22 AM | #16 |
Rep 114
I have heard that it can have a negative effect on GPS and radar detectors. I recently replaced my windshield and opted for the regular windshield. Food for thought.
ARC-8 Wheels - Stoptech Trophy BBK - Solid Subframe Bushings - Purple Diff Bushings - Topspeed X-pipe - Megan Catback - AFE Carbon Intake - RE Pullies - BPM Tune - GAS Monoballs - ECS Front Sway - GTS Wing - Autosolutions SSK - Vibratechnics Motor Mounts - Revshift Tranny Mounts - VAC Bearings - Bilstein PSS10 Coilovers - Dinan Camber Plates - Ultra Front Strut Bar - BSW Ghost Subs - Matek Diffuser
06-23-2022, 01:01 PM | #17 | |
Derbo Tuning
3612
Rep 3,027
Car GPS should not be affected as it is in the sharkfin.
IG:ruhrohz_m3
06-24-2022, 11:19 AM | #18 | |
Rep 68
06-24-2022, 11:30 AM | #19 |
Rep 364
Drives: 2011 AW E92 ZCP 6MT
Garage List 2021 Toyota Tacoma [0.00]
2020 BMW X5 [9.00] 2020 Subaru WRX [0.00] 2019 Ford Raptor [0.00] 2011 BMW M3 [0.00] |
I replaced my OEM windshield at Safelite with polarized glass last summer. The purple tint is noticeable and I think compliments the car and didn't require immediate tinting. I'll still tint it when I have the existing tint refreshed.
While my glass coverage covered it, the receipt was $767.20.
AW 2011 E92 ZCP 6MT single hump w/speed cloth.
Alpine Stage 2 | Apex Manufacturing X-Pipe | Corsa | BayOptiks | Haimus Racing CF Plenum MW 2020 G05 X5 with delicious coffee interior |
Bmwdoubles_194.00 |
06-24-2022, 01:59 PM | #20 | |
Rep 524
Safelite said it's not polarized. It's their solar protection that has a purple hue.
06-24-2022, 02:59 PM | #21 | ||
Derbo Tuning
3612
Rep 3,027
IG:ruhrohz_m3
Davisca4552207.50 akkando5869.00 |
06-26-2022, 02:59 PM | #22 |
Derbo Tuning
3612
Rep 3,027
Just took a pic of friends e90 this morning. There are matrix dots on his solarized one.
IG:ruhrohz_m3
