06-24-2022, 01:28 PM | #1 |
Rep 4
2015 M3 No yellow or red tach lights ever
Hi guys,
The yellow and red lights that are on the tach do not appear on my car. There are no lights ever on my tach. I'm talking about the RPM limiter lights that adjust when warming up the car and the red line lights. Neither are present on my car. If I bring the rpms up to 7k, I also never get a shift indicator. It's like they are totally dead, or not an option on the car. Has anyone else had this issue? Thanks for any response. |
06-25-2022, 12:13 PM | #4 |
Rep 1,371
For me, they only light up when I drive the car very aggressively from a stand still. Have you tried turning everything sport+ and MDM mode then aggressively accelerating from a stand still?
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
06-28-2022, 09:59 AM | #6 |
Resident BMW Fanboy
259
Rep 866
Your cluster is either broken, modified, or aftermarket. No factory US F80 has km/h markings.
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
WordOnRoad313.00 |
06-28-2022, 10:14 AM | #7 |
Rep 502
Never seen one like that. Maybe it has custom inserts since the stock ones aren’t flat where the numbers are.
The speedometer looks like it was cut by hand at the bottom. |
WordOnRoad313.00 |
06-28-2022, 10:22 AM | #8 |
Auto/DCT Zealot
502
Rep 378
Drives: M3, Miata
Yeah, looks like the two speedo/tachy face plates are overlays, evident by the slightly-off trapezoidal cuts along the bottom of both.
Also note how each of your gauge notches/cross-hatches are pointy triangles; the factory gauges are little flat rectangles: https://commons.wikimedia.org/wiki/F...5539562%29.jpg As Keca said, the stock gauges aren't flat like yours. They're kind of triple-layered/indented. The overlay is probably not see-through where your shift lights are. Someone probably wanted KM/H markings and got custom overlays. |
WordOnRoad313.00 |
06-28-2022, 10:27 AM | #9 |
Rep 4
The car is from Canada originally. That is why the KM is on the speedometer. It only has 15k on the car and nothing has been modified. I guess I will pull the instrument panel out and see if I can find something.
06-28-2022, 11:16 AM | #10 |
Rep 179
Drives: 2015 BMW M4 Cabriolet
That's definitely not a gauge cluster from a Canadian car ... ours don't have MPH markings at all:
At the very least someone put in new faceplates (my guess is to add MPH markers to make it sellable in the US). You can see from your pictures that the new insert is covering the shift lights.
2015 F83 ///M4 Cabriolet, Tanzanite Blue on Black extended leather w/DCT, Premium package and LEDs.
BMW335iOn18s259.00 |
06-28-2022, 11:32 AM | #11 |
Auto/DCT Zealot
502
Rep 378
Drives: M3, Miata
The instrument cluster is relatively easy to remove. Just one screw at the top of the hood. You'll need a short screwdriver and you'll have to move the wheel. Also make sure you disconnect the battery or you'll throw a code and potentially zap your gauges.
06-28-2022, 11:56 AM | #12 |
Rep 2,788
Drives: 2020 M4 ZCP / 2023 X3 M40i
Unless you bought this car brand new and was the 1st and only owner, I don’t see how you can say this with any certainty.
06-28-2022, 02:08 PM | #13 | |
Rep 304
06-28-2022, 05:21 PM | #14 |
Resident BMW Fanboy
259
Rep 866
Look at the pic of the Canadian/rest of world cluster. Looks nothing like yours.
06-28-2022, 05:30 PM | #15 |
Rep 3,308
WTF?
Someone made that instrument cluster at home. There is something not right there. Canadian cars only have KM. Looks like they tried to do some kind of custom thing |
07-02-2022, 03:42 PM | #18 |
Rep 1,201
The OP is too embarrassed to post here again knowing he got fucked. Probably bought a stolen car from somewhere else in the world and thought it was legit.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
G35POPPEDMYCHERRY4998.50 swagon13567.50 |
07-02-2022, 11:42 PM | #19 |
@rxfid on instagram
66
Rep 64
Drives: 2016 BMW M3 LSB, 2016 M235i
if you have heads up display, switch it to the regular speed and not the m view. Should light up under hard acceleration in manual mode. let me know how it goes
07-03-2022, 11:14 PM | #20 |
Racecar Driver
1312
Rep 1,989
Drives: BMW M4
In hind sight, didn’t need to take a picture going 30 MPH. Stationary would of work.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
