07-01-2022, 01:13 AM | #1 |
Rep 1,057
Tension strut torque specs?
Can anybody confirm what the torque specs are for the tension struts?
I know the bushing is 100nm/74ft-lbs plus 90 degrees. What I am unclear on is the ball joint. I've seen in some places its 165nm/122ft-lbs and others said 175nm/129ft-lbs. I have not seen a screenshot from TIS that says the torque and I would consider this the undisputed answer. Can anybody confirm what it is? A screenshot from TIS would be even better. |
07-01-2022, 01:55 AM | #2 |
Rep 1,057
I found the answer, and it is the 175nm/129fl-lbs.
Totally forgot about this thread, and managed to confirm in TIS as well. https://www.m3post.com/forums/showthread.php?p=20922983 |
