12-15-2008, 11:18 PM | #1 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Groaning from rear diff area in slow turns
Anyone get an short and intermittent medium pitched groaning/hum sound from the rear end of the car when taking slow but sharp turns, first gear?
Only does it under slight power, experimented with turns in neutral and no sound. Sounds like its coming from the differential. It's not tires/wheels, doesn't sound like bad wheel bearings in my experience but I'm not sure. |
12-15-2008, 11:25 PM | #2 |
Rep 237
yes, you need to take her in and get the service bulletin performed. THey add a higher viscosity diff fluid.
Widely known issue, but it's not hurting your car so walk, don't run, to your dealer BTW- the sound is diff clutch plates rubbing (did i say that right?) |
12-15-2008, 11:33 PM | #3 |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
Yeah, take to the service dept they will put a half litre of FMBooster fluid into the diff.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
12-16-2008, 08:20 AM | #4 |
Rep 1,043
there is a LONG post on this already... this noise is normal for a LSD, and the service bulletin addresses customers unhappy with the noise, not that there is actually a mechanical problem. Lots of much more expensive cars w/ LSD exhibit this noise at slow cornering as normal operation....
12-16-2008, 08:35 PM | #8 |
Rep 1,864
Drives: F80 M3
thanks all, thankfully I enjoy going to my dealership they have better coffee than my office
12-17-2008, 12:13 PM | #9 |
Rep 1,043
i have heard though that TOO much of the additive from the service bulletin to reduce noise also could reduce performance (cause slippage) of the lsd (probably only on the track)
12-17-2008, 05:21 PM | #10 |
Rep 1,597
No more than 1/2 a litre is to be added!
