07-16-2022, 09:40 PM | #1 |
Rep 2,072
car reporting 6mpg ... stuck injector? or o2 sensor?
I've got an o2 sensor code (274a) that keeps popping up, and I plan on replacing those in a weekend or so. In the meantime, I noticed that the car sucked down a tank of gas in ~190 miles, so i flipped into the mpg display and reset it (it was showing ~18, but that included the ride from DC to Chicago when I brought it back). It sat at 6mpg just tooling around down. Then after a few miles it started ramping up from 6 (it was pegged at 6.0 and not moving).
i know bad o2 sensors will make it run rich.. is that what i'm seeing? or do i have a stuck injector? is there anything I can do to test for that short of pulling them out and actually testing them? car has ~60k miles on it.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
07-17-2022, 10:47 AM | #2 |
Rep 370
6 mpg 274a should be precat O2 sensor in bank 1. I would start with replacing it. It would be interesting to see your STFT and LTFT. Problems with O2 can and typically will result into rich/lean. Btw if you are running so so rich then I would not drive until this is resolved because you can damage your catalyst. Do you smell fuel from exhaust gases?
DrFerry6731.50 |
07-17-2022, 12:58 PM | #3 | |
Rep 2,072
Car is running test pipes and I do smell some fuel from the exhaust but hard to tell if it's just because it's missing the primaries...
07-17-2022, 05:10 PM | #4 |
Rep 370
Possibly something like this:
Or INPA: https://bimmerprofs.com/stft-and-ltft/ Or Carly, CarScanner, ScanMaster-ELM etc. |
DrFerry6731.50 |
07-18-2022, 05:41 AM | #5 |
mTekMods
2161
Rep 2,912
IIRC you bought the car with a tune on it already no? to really have a baseline you should flash it back to stock, correct the errors and go from there.
If there was a stuck injector you would know. fwiw my supercharged e90 gets like 15mpg driving normally shifting at 3500RPM.
07-18-2022, 08:33 AM | #6 | |
Rep 2,072
re: "you'd know" -- is it sudden death in that scenario? not sure how long it takes to get to bore wash / hydrolock
07-18-2022, 09:34 AM | #7 | |
mTekMods
2161
Rep 2,912
A primary cat O2 sensor would throw the fuel trims way off, it could explain what youre experiencing here.
kolosy1548.00 |
07-18-2022, 10:45 AM | #8 | |
Rep 1,128
RE: hydrolock, it typically happens quickly. See examples of water ingestion when driving a car with a low cold air intake through a body of water. You'd hear rod knock immediately if it didn't kill the engine. It doesn't take much water to beat the bejeezus out of bearings, you could pull an oil sample and pan for gold to verify. Amraz sounds like he's got you on the right track. |
kolosy1548.00 |
08-08-2022, 10:38 PM | #9 |
Rep 2,072
me again.
replaced the precat O2 sensors with shiny new bosch ones. The ones that came out were completely black (not sure if that's a bad thing necessarily, though) and not OE. dropped in the new ones, and decided to not reset adaptions but just drive it for 50 miles. here i am, ~60 miles later. Haven't gotten a CEL since doing this, but mileage still sucks. Now getting ~8 in the city, low teens highway. The car does have an Evolve Stage 2 tune from the PO, but a little bit of research shows that that should still be in the mid teens combined. I've got new plugs and new injectors sitting here that I'll throw in because I already have them, but ... other thoughts? oh and as someone else pointed out -- car sounds and behaves great otherwise. just keeping an eye out for what's happening.
08-09-2022, 12:10 AM | #10 |
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
The tune. Remove it.
08-09-2022, 07:38 AM | #11 |
Rep 2,072
08-09-2022, 08:26 AM | #12 |
Rep 954
Are you saying that you are manually figuring mileage, based on actual gas used and miles driven, OR are you saying this is what the on-board comp is telling you? I can tell you that once you move away from stock (tune, intake, exhaust, etc.) the on-board comp loses its mind and is all but useless. Just saying, not sure it would be this far off, but still...
08-09-2022, 09:24 AM | #13 | |
Rep 2,072
... that said, since i've only done 60 or so miles since changing the sensors, i haven't gone through a tank and haven't thought about what you're saying. i'll keep a manual eye on it for a bit then and see what happens.
08-09-2022, 01:41 PM | #14 | |
Rep 725
