07-21-2022, 03:42 PM | #1 |
Rep 546
Ohlins Height and Preload
Question about the recommended settings. Height is 158mm and preload is 194mm. Adjustment range 15mm
If I lower height to 148mm do I also change the preload by the same amount? If so is it 184mm or 204mm
2011 E92 M3 AW DCT
IG - rod.bearings |
07-21-2022, 06:32 PM | #2 |
Rep 4,178
Ohlins R/T height is separately adjustable from the preload. Preload is set by the lower spring collar. Height is set by the [gold] collar which the spindle clamps onto.
