08-01-2022, 11:27 AM | #1 |
Rep 13
S55 runs like a rotary, no fault codes??
Hello,
Need some help with my f82. My problem started a day ago on the highway, at wot sometimes felt a slight hesitation. Now my car runs like a rotary at idle and thru the rev range when revving and also shakes a lot. Like it's running on 5cil. BUT I have no error OR fault code. Scanned with ISTA and also on bootmod shows no fault codes?? Where do I start with no fault codes? Recently changed downpipes with stock cats (checkt al lambda connections and seems fine?) My dealer is booked full for an other week so any help would be appreciated! Sorry for bad English!!! |
08-01-2022, 05:17 PM | #2 |
Rep 1,371
A wild guess here but it's possible the car was coded to run aftermarket downpipes and something is wrong with the stock cats you just installed yet the car is being prevented from showing it. Again, a wild guess.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
08-01-2022, 05:42 PM | #3 | |
Rep 13
Yes flashed back to stock and now I do get the errors, cel, fault codes etc!! |
08-01-2022, 05:47 PM | #4 |
Rep 1,371
Were they used cats? Or new?
08-01-2022, 05:55 PM | #5 |
Rep 5,188
What codes in BM3? Send a pic.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
WordOnRoad313.00 |
08-01-2022, 08:13 PM | #6 |
Rep 13
Think it's my injector, already switch coilpack and stays on cylinder 2.
Weird that bootmod 'blocks' these faultcodes and drivetrain errors etc !? I did have o2 sensor cel off in my tune but don't think these codes have anything to do with o2 sensor’s no ? Last edited by F82be; 08-01-2022 at 08:20 PM.. |
08-01-2022, 08:46 PM | #7 |
Rep 5,188
BM3 doesn't block codes unless you specifically put them in the ignore list. It can take an injector a little while to "break". Are you running E85 on stock turbos?
Get your plugs out and look at them. That's always my first step. If #2 is wet with fuel then you know that DI broke. If the cylinder has any fuel down in it then it needs to be sucked out.
08-02-2022, 04:05 AM | #8 |
Rep 13
It was definitely bm3 blocking the codes (installed it myself months ago, didn't block any codes). Probably scanned 20 times yesterday with bm3 app, ista, my autel scanner and even with my MHD app from my previous car. When I flashed back to stock the codes popped up right away.
No, pump gas on stock turbo's. |
08-02-2022, 06:45 AM | #9 | |
Rep 5,188
08-02-2022, 02:33 PM | #11 |
Rep 5,188
I was running custom E85 map and had an injector failure. The dash showed limp mode and requested immediate shutdown. Not sure why yours didn't.
08-02-2022, 04:44 PM | #12 |
Rep 1,371
Man, that's crazy. Another reason for me to get off the fence on a stage 1 tune...
08-02-2022, 06:22 PM | #13 |
Rep 13
Told bootmod about the problem, all i got was 'check your plugs an coils' and 'it should not be doing that"
Love bootmod but c'mon.. Might be a fault or something in the ' cs+ ' software. |
08-03-2022, 06:57 AM | #15 |
mTekMods
2161
Rep 2,912
Check the compression of the affected cylinder.
08-06-2022, 09:24 AM | #16 |
Rep 13
Update;
Went to all the trouble of changing injector 2 and it turned out to be Spark plug cylinder 2 that died (i know should've changed plugs first...) Note: My spark plugs were super stuck, needed to go back and forward and even needed a prybar on my ratchet to get them out, is this common? It's my first time changing plugs etc myself Last edited by F82be; 08-06-2022 at 09:59 AM.. |
TopJimmy5510.50 |
08-06-2022, 10:27 AM | #17 | |
Rep 5,188
TractionControlDelete4601.00 |
