08-10-2022, 03:49 PM | #1 |
Rep 666
Looking for DIY on retrofitting the pull up sunshade on side windows
Hi all,
I'm able to source both rear door panels which have the pull up sunshade option. Upon this past weekend, I took out my original door trim panels which are just standard. It looks like all the pop-up rivet locations will match, but along the upper rail, the metal clips of my current setup don't appear to snap into any holder on the sunshade trim panel. Does anyone have experience retrofitting it? How does the upper rail portion get secured onto the inner door? By the way, for the hook at the top, I'm able to source the hooks, self-tapping screws, and expanding nuts. Should be able to drill open some holes through the original inner trim sill to make this work. Just need to know how to secure the door trim panel's upper portion along the window rail.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
