08-19-2022, 09:29 AM | #1 |
Rep 19
E87 right subwoofer-no wires
Hi,
I recently bought E87 116i I had many faults, and now I have to solve this one. Diagnostics says: — C544 Speaker output lines, front right line disconnection I pulled everything out, and I see there is no speaker and no wires Then I pulled out everything on the left side to see how it should look, and everything is fine. PS: On right side I have 2 more faults, probably because someone washed seats and spilled too much water 93C2 MRS Seat mat, seat occupancy detector, passenger. Seatbelt reminder is always active, and airbag faulty red screen and lamp are constantly on.(this will someone else solve I'm saying just so you know that there are 3 faults on same spot) Please help! Last edited by speedy24; 08-19-2022 at 09:56 AM.. |
08-21-2022, 03:56 AM | #2 |
Rep 206
the wire is there, so basically the sub was taken out....try a breakers for a 2nd hand unit and replace it there.
if you want to test the wires work, put the other side in the side that's missing the sub and see if the code comes up for the other side, then at least you know the wiring works.
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it...."
Ferris Bueller |
08-21-2022, 06:35 AM | #3 | |
Слава Украине!
2336
Rep 2,443
https://www.realoem.com/bmw/enUS/sho...diagId=65_1483 https://www.realoem.com/bmw/enUS/par...&q=65139204786
08-22-2022, 12:09 PM | #4 | |
Rep 19
08-22-2022, 12:13 PM | #5 | |
Rep 19
I don't know what audio I have. I have tweeters, if that can tell you something. These are numbers on subwoofer from left side. 6513 9204785-03 |
08-23-2022, 07:12 AM | #6 |
Rep 206
E87 had covers....it could just be covers in the door sails and no tweeters.
Ferris Bueller |
08-24-2022, 05:53 AM | #7 |
Rep 19
08-25-2022, 03:44 AM | #8 |
Rep 206
i was talking about the tweeters.
Ferris Bueller |
08-26-2022, 02:51 AM | #9 |
Rep 19
08-26-2022, 05:13 AM | #10 | |
Rep 206
google how to add....go to a scrapyard/breakers to get the 2 clips that fit to the speaker in each door. plug and play. then just clip the tweeter in place.
Ferris Bueller |
08-29-2022, 04:17 PM | #11 | |
Rep 19
But I have to solve first these problems speakers and JBE (some idiots put JBE from wrong car) |
