08-24-2022, 02:56 PM | #1 |
Rep 38
Drives: 2010 BMW M3, 2017 BMW M760I
[Expert Needed!] Do I need to replace my throttle actuators?
Hello everyone,
So I had my 2010 M3 for almost 4 months now. I did the rod bearing job last month and decide to take the car to the track. However, only after 2 sessions, I ran into problems. First it was the braking and the ABS light, with message: Braking/Chassis Stabilization Malfunction, ABS Malfunction. After several restart and some normal driving, these lights disappear. Later on, the check engine light appears with message: Increased Emissions. Due to those lights, I went back home early. During the 2.5 hours of highway driving, I didn't notice anything strange. The car runs smooth and the power delivery is just fine. After I arrived home, I used OBD and got all those errors: 2B2C: Throttle Initialization Bank 1 2B59: Coolant thermostat monitoring 277B: Fuel Cap message 27C7: Lambda probe adaptation trim control bank 2 2729: Lambda probe thrust diagnosis in front of Kat Bank 2 2727: Lambda probe plausibility before Kat Bank 2 5DA3 - Speed controller front right Start detection v_comparison 5DA6 - Direction of rotation detection right front 5DA1 - Speed control front right extrapolation 5DA0 - speed control front right electrically faulty 5FF1: analog wheel speed left: deviation too big 5FF2: analog wheel speed right: deviation too big 5FF3: CAN wheel speed front left: deviation too high 5FF4: CAN wheel speed front right: deviation too high 5FF8: CAN wheel speeds: timeout or invalid After a diagnose at a bmw-specify race shop, they told me that the throttle actuator is bad and recommend me to replace both. Besides, there are some sensor replacements as well as a thermostat replacement. The shop quoted me around 2800 to do all of these. Now here comes the question, I didn't see any error code that is related to TA. Although there is a "Throttle Initialization Bank 1" error, I am not sure if it is related to TA or not. Can anybody provide some advice? I don't want to replace TA when it is not broken yet. Thanks a lot! |
08-24-2022, 07:47 PM | #2 |
BimmerPost Supporting Vendor
3769
Rep 2,912
Drives: 2011 E93 M3
Yes, 2B2C is a throttle actuator fault. I
It looks like you need more thorough diagnostics however. Actuators communicate within the powertrain network along with the DSC and can fail in a way that causes a lot of DSC faults. This would usually result in other faults though. I'd still replace the actuators. Treatment with BMW's ISTA-D software would be required to diagnose properly but it looks like you have a lot of unrelated issues present that need to be sorted out. |
kolosy1548.00 Ultimatemj53.50 |
08-24-2022, 11:09 PM | #3 |
Rep 65
Agree with deansbimmer, and would add replace the wheel speed sensors...they are cheap, easy to replace, and can cause a 'cascade of errors' that cause you to chase your tail.
'12 E92 M3 ZCP Ruby Black Metallic, BBS E88, Ohlins R/T, Eventuri, Dinan exhaust, Tune +36whp, S752 + JL Audio XD1000/5 & 12w6v3, Dinmann |
08-25-2022, 07:34 AM | #4 |
3769
Rep 2,912
Drives: 2011 E93 M3
I would not replace any wheel speed sensors until further testing of the CAN signals and other control systems. It's extremely unlikely that multiple wheel speed sensors failed simultaneously.
08-25-2022, 01:18 PM | #5 |
Rep 954
Having that many codes pop up at one time may also suggest you may have a battery that is on the way out. Voltage issues can also trigger oddball codes. That many at once is nuts!
08-25-2022, 08:07 PM | #7 |
Rep 954
Ah, yeah that makes sense. Good to know, thanks!
08-25-2022, 09:20 PM | #8 |
Rep 3,994
While a TA might be on the way out.
Given time, I would clear the codes and see which ones come back first and address that first. Also check the live readings to see which/if a speed sensor is bad and replace that. Then after that if the TA code keeps coming back I'd look at changing those along with the tstat and cool temp sensor. If you are feeling preventative then change the waterpump while in there. But if this is your daily and you can't afford the downtime. I guess you can always do it all at once and hopefully cover it all in one go. |
08-26-2022, 08:41 PM | #9 | |
Rep 38
08-26-2022, 08:44 PM | #10 | |
Rep 38
08-26-2022, 09:05 PM | #11 | ||
3769
Rep 2,912
Drives: 2011 E93 M3
DrFerry6731.50 |
08-27-2022, 02:47 AM | #13 |
Rep 146
If you have the time to wait I highly recommend getting an upgraded set from EuroParts. Way cheaper, upgraded gears, and all circuit board components tested or replaced.
https://eupartspalace.com/product/bm...ttle-actuator/ |
DrFerry6731.50 |
08-28-2022, 03:50 PM | #14 | |
Rep 38
08-28-2022, 03:51 PM | #15 |
Rep 38
Thanks, this makes me feel bit better
