BMW M3 Forum (E90 E92)
Mporium BMW
      12-26-2008, 06:04 AM   #1
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
Springs Comfort & performance
From Eibach, H&R Sport, and RDSport. Which do you guys think would be the most comfortable to least comfortable and provide the best performance to least performance?
I've heard quite a bit about the Eibach's and H&R's but when it comes to RDSport, not much has been said other than it gives the lowest drop out of the three. Can anyone chime in who has had experience in any or all of these springs?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      12-26-2008, 08:46 AM   #2
Technic
Technic's Avatar
2295
Drives: 2021 i3S, 2024 i4 M50
You will find all kind of experiences about which one is best in this forum, but the bottom line is that the more you drop the least the OEM shocks will last; although you will not find reported problems right now in this forum, the reality is that it is simply too early to tell the effects of lowering springs to the OEM shocks longetivity. Therefore you need to consider as well what to do about the OEM shocks, especially about the EDC if so equipped. That also will affect comfort and performance, even more so than aftermarket springs with OEM shocks.
      12-26-2008, 01:01 PM   #3
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Stock will handle better and ride better than any of the set-ups you mentioned. The reality is that a more compliant suspension will out handle a stiffer one in real world (back roads) situations. The lowering does not improve handling since the lowered center of gravity is offset by the compromised suspension geometry. I'd venture to say that even on the track, the stock suspension will win out over the spring swap solutions.
      12-26-2008, 01:31 PM   #4
urbo73
Drives: 2021 BMW M340i xDrive
+1 But this has never stopped people from screwing with suspensions w/o understanding the implications. Most are done for looks.
m3post
