10-11-2022, 04:34 PM | #1 |
Rep 4
Drives: BMW X5 50i
152022 Fault after changing Plugs, and injectors?
I'm get a drive train malfunction warning and my X5 50i will not start. Pulled the codes. I am getting the following:
152022 Relay, ignition and injectors, supply voltage, ignition 2: short circuit to ground Any help leading me in the right direction would be greatly appreciated. I feel like it's something simple, I'm over looking or don't know about. TIA |
10-11-2022, 09:11 PM | #2 |
Rep 1,036
You are sure there is no wire damage or issues with the coil pack? Have you tried to move it around to se if the issue moves with it?
Also when you did the injectors, you did set the new pulse values? |
10-12-2022, 11:00 AM | #3 |
Rep 4
Drives: BMW X5 50i
EU6 injectors flow rate numbers matched what came out. Reset adaptations. I'm beginning to believe it may be in the wiring.
