10-23-2022, 12:51 PM | #1 |
Rep 17
bimmerlabs tune
Anyone here have successfully flashed their ECU to the BImmerlabs tune?
I'm looking to do it and can't find the chassis code for my 128i. Should I use the E92 chassis code instead? |
10-27-2022, 04:49 AM | #2 |
Rep 205
what is your engine code? check if your engine is a 3.0L to get to 130/330 spec.
the tune i used works for 125i, which is usually N52B30, so it's a software tune that holds it back to 125i spec of 160kw instead of the 130i spec of 190-195kw. it worked for me as i have a 125i. i am not sure on the 128i tune.
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it...."
Ferris Bueller |
10-27-2022, 10:45 AM | #3 |
Rep 2,806
Good thread here:
https://www.e90post.com/forums/showthread.php?t=1736657 I haven't done it, but plan to soon.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
02-06-2023, 12:44 PM | #4 |
Rep 301
Drives: 2010 128i ZSP 6MT
I just did mine last month, following the link that gjm120 posted above. Just make sure you have a BimmerGeeks Pro K+DCAN cable.
https://www.bimmergeeks.net/product-...eeks-pro-cable |
