11-08-2022, 07:22 AM | #1 |
Rep 12
Handling of the E93 M3 Convertible
Having owned my E93 M3 convertible for a few months now, I've noticed that the handling is better with the top up. (for context, I have a lot of track experience and am an 'advanced' driver and have multiple Porsches)
With the top down, the car has a tendency to understeer and needs a lot of trailbraking to help it turn. I assume that this is largely because putting the top down shifts the weight balance towards the back of the car, thus less grip at the front. With the top down, I've also noticed that the handling of the car isn't great when braking hard and late and then trailbraking, as one would do on a race track. This could partly be due to the understeer, but I think that twisting of the car under that transient load could also be a factor, resulting in the dampers getting confused (I have EDC) and the front of the car not staying planted. It seems like putting the top up would stiffen the car, since the roof is metal and locks into the A-pillars. What are your experiences with the handling of the car, top up versus top down? Does the car have adjustable sway bars, so that the balance can be made more neutral with the top down? (yes, I know that may make the car slightly understeery with the top up) How does the handling of the convertible (top up) compare with the coupe/sedan? I know the convertible is more than 400 pounds heavier and likely not as stiff, but most of the extra weight should be at the bottom of the car, so the convertible may not have much of a penalty in terms of center of gravity height, and acceleration of the convertible is plenty fast for me. |
11-08-2022, 08:36 AM | #2 |
Rep 12,736
An alignment could help, and would be cheapest. Next, I'd add camber plates, but that might not align with your comfort and drivability goals.
Swaybars are not adjustable, and you'd want to add stiffness to the rear to help with what you're describing. Changing the rear sway bar is a labor intensive job that requires dropping the rear subframe. If you do this, add solid subframe bushings while you're at it.
Instagram; @roastbeefmike
11-08-2022, 08:49 AM | #3 |
Friends don't let friends ESS
3223
Rep 886
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
Mine was lowered on H&R sport springs and aligned to factory specs. I always thought it handled better top down on the streets and in canyon carving. HOWEVER I've had a single hpde and don't have the skillset to describe what you are picking up and relaying in your experience. That said, top up track driving at Portland international raceway the car was noticeably top heavy in the corners and to my feel, eliminating that with top down was a bigger gain than problem.
11-08-2022, 08:54 AM | #4 |
Rep 2,072
i do wonder if the car becomes stiffer with the top up, but i'd imagine the weight transferring further back is the bigger contributor.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
11-08-2022, 04:28 PM | #5 | |
Rep 12
11-08-2022, 07:19 PM | #6 |
Rep 12,736
german engineering... they'll tell you its perfect as-is.
11-08-2022, 11:08 PM | #7 | |
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
Sorry but you bought the wrong M3 if you wanted handling. |
byroncheung179.00 |
11-09-2022, 05:18 AM | #8 |
Rep 1,067
As an E93 owner (not my only M), I will say this.
She isn't the most athletic in the stable, has a little too much junk in the trunk, but loves to go topless and is still a fun ride.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
11-09-2022, 07:52 AM | #9 | |
Rep 12
I'd consider getting a coupe, but advantages of the convertible are: - Sound with the top down - Open air experience with the top down - Ability to put the top up to get the handling closer to the coupe |
11-09-2022, 09:27 AM | #10 | |
Rep 756
Getting the e93 closer to handling to an e92/e90 is like saying I took 300 lbs of unnecessary weight out of my Acura MDX so its now closer in handling to my e92 m3. It means nothing, a fixed roof e9X traps about 4-5 mph faster and would smoke a vert around a track. Enjoy the vert for what it is but I don't see the point of making it a performance discussion, its the wrong tool for the job. Some cars like the S2000 and 911's dont suffer a huge vert penalty performance wise, but in this case 450 lbs is a LOT and offers little to compensate other fundamental differences in the chassis and related components |
11-09-2022, 10:07 AM | #11 |
3223
Rep 886
I think everything you say is true - but adding viewpoint that the extra weight of the vert actually came in handy when I added a Harrop supercharger. I didn't have nearly the traction issues on stock tire sizes (255/235) that others in the lighter e90 and e92 face with that torque-focused induction unit. That, in addition to the DCT, gave me 0-60 speeds reliably at 4.0 seconds that I can't come close to matching in the Harrop e90 6MT. A lot of that has to do with the slower shifting of the MT compared to the DCT, but I definitely struggle more with traction in that off the line experience in the harrop e90 on a wider tire setup 265/245. That SC unit adds 80 pounds to the engine compartment and I wonder if part of my experience that top down driving was so good is in part because of that counterweight to the roof in the trunk.
Acknowledge that OP's track observations and my street performance observations are two different scenarios. |
gnx759.50 |
11-09-2022, 04:01 PM | #12 | |
Rep 12
Extra weight isn't necessarily a big problem if the F/R balance is good and CG is kept low; Tesla Model S is heavy, but the batteries are at the floor and the handling is excellent. Acceleration is unrelated to handling, and I think the acceleration of the E93 is amply strong for a road car. I'm not tracking the E93 because I have Porsche GT cars for the track which are much faster than any E9x. |
CamasM3e933222.50 |
11-09-2022, 07:50 PM | #13 | |
Rep 2,072
11-09-2022, 08:00 PM | #14 | |
Rep 12
If I can get an E92 with relatively low miles at a decent price, I may buy that and keep the E93. A bit redundant, but if they're really noticeably different cars, it could make sense. |
CTMike262.00 |
11-09-2022, 08:16 PM | #15 | |
Rep 2,072
11-09-2022, 08:28 PM | #16 |
Rep 333
Not sure why it offends certain folks that some people want their E93 to handle as well as possible. Whether or not that’s “better” than an E92 is irrelevant. It magically becomes a track car the moment it’s driven to a track.
Gone but not forgotten: 2005 X3 2.5 6spd, 2011 X5 50i, 2015 328d Wagon Last edited by CTMike; 11-11-2022 at 05:20 AM.. |
qskid2810.50 byroncheung179.00 |
11-10-2022, 08:14 PM | #17 | |
Rep 12
And I strongly suspect that the factory balance of the E93 was conservatively set to have very slight understeer with the top up, resulting in more significant understeer with the top down. I want to dial out the understeer with the top up, which will reduce the understeer with the top down. |
11-10-2022, 08:26 PM | #18 |
Rep 2,072
odd to infer that someone's telling you what to do when you get answers to your direct question. ¯\_(ツ)_/¯
