11-10-2022, 04:12 PM | #1 |
BMW addict
395
Rep 485
Another dash cam thread …
I’m in need of an LTE ready dash cam with parking mode.
Currently experimenting with an OwlCam. The alerts seem to be a bit sporadic. And there is no video buffering feature, so the person etc. that might damage your vehicle isnt captured approaching vehicle because the recording doesn’t start until after the event happens. Thoughts/ experiences with other cams? I’m considering a blackvue 750x For better coverage due to the rear camera. However it has no interior view.
M3 CS LRG CCB MPE MHAS
11-10-2022, 08:53 PM | #2 | |
Rep 893
11-10-2022, 10:57 PM | #4 |
M Enthusiast
438
Rep 626
Drives: 2018 F80 M3 ZCP
I have the Blackvue DR900x 2-CH paired with the CM100 LTE Module. Works fantastic. I get push notifications if anything hits my car on my phone with live view. Also have the B124x battery with the B124E extension pack. Front records at 4K and the rear records at FHD.
Got a T-Mobile prepaid sim card thats $10/month for 2GB of data. Thats pretty sufficient to be checking the cameras live view for fun a few times a day plus playback of the recordings. But do keep in mind that the CM100 LTE Module only works with GSM carriers and not CDMA. Not cheap by any means though. IIRC this entire set up ran me close to $1,300 but I did the install myself so saved a bit there. Records about 45 hours on the battery packs alone in parking mode. Gives me a peace of mind when parked anywhere for longer periods of time.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) Last edited by s55jesus; 11-10-2022 at 11:04 PM.. |
11-11-2022, 05:39 AM | #5 |
BMW addict
395
Rep 485
Wow very nice. Why did you go with the 900 over the 750? I was just going to hardwire vs battery.
Where did you mount the external LTE module? I was trying to avoid having another component mounted on my windshield Thanks |
11-12-2022, 05:44 AM | #7 | |
Rep 628
Highly recommend getting a dashcam battery pack like the Cellink Neo or Blackvue B-124X. |
damageprone580.50 |
11-12-2022, 08:02 AM | #8 | |
Rep 1,988
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO 2016 340i xDrive : AW/CR (sold) |
11-12-2022, 08:03 AM | #9 | ||
Rep 1,988
11-12-2022, 08:05 AM | #10 |
Rep 1,988
I am due for an upgrade. I have the thinkware 750 or so from 2016 and it's been great. I'm sure tech has improved a lot now so looking for something new. I see the latest thinkware is the 1000 but that's been out for two years already. Waiting for them to release a newer one before finally pulling the trigger.
11-12-2022, 12:59 PM | #11 | ||
M Enthusiast
438
Rep 626
On hot days down in So Cal, I've seen it go as high as 120F when it's charging. Under normal conditions where ambient temp is 60-70F, it hovers around 100F. But these aren't the traditional lithium ion battery packs. It was meant to stay inside a hot car so it uses lithium iron phosphate instead. Holds up to heat much better.
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
11-13-2022, 02:53 AM | #14 |
M Enthusiast
438
Rep 626
I hardwired mine to the rear fuse box with an extra 15 amp fuse. The battery pack only charges when the car is running.
JTM09395.00 |
11-15-2022, 03:25 PM | #15 |
Rep 1,055
They get hot but they're LiFePO4 batteries that can withstand the heat in the car. As added security, I put them in a battery bag to protect against any fire. I ran this setup in Vegas during 117F summers.
https://www.amazon.com/COLCASE-Firep...s%2C143&sr=8-9 Last edited by damageprone; 11-15-2022 at 03:31 PM.. |
White3401396.00 |
11-15-2022, 08:06 PM | #16 | |
Rep 2,077
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
11-15-2022, 10:47 PM | #17 | |
BMW addict
395
Rep 485
10-20-2023, 01:20 AM | #18 | |
Rep 6
10-20-2023, 04:41 AM | #19 | |
M Enthusiast
438
Rep 626
You do not need to mount the LTE module on the windshield. I have mine tucked into the right dash panel by the passenger door. Ran the cable by the roof down the passenger A pillar and into that little compartment. It picks up signal fine and I hid the excess wires in there as well using a few zip ties. Hope that helps.
