11-13-2022, 09:25 PM | #1 |
BMW addict
395
Rep 485
wheel swap with CCB's
I am new to the world of carbon ceramics.
Anything I need to watch for when swapping wheels? thanks
M3 CS LRG CCB MPE MHAS
11-13-2022, 09:38 PM | #2 |
Rep 502
If you still have wheel bolts and not wheel studs, be careful when removing the wheels. It's best to use those temporary studs at minimum to prevent your wheel from sliding off the hub and damaging your rotors. Or swap over to actual wheel studs.
11-13-2022, 10:10 PM | #3 | |
M Enthusiast
438
Rep 626
Drives: 2018 F80 M3 ZCP
Also just as a side note, you should not use harsh wheel cleaner chemicals on carbon ceramics. They absorb the chemicals and overtime, will not be good for the rotor. For wheel cleaning with ceramic rotors, just use a mild car wash soap without any sort of additives (wax, SiO2, etc..) There is not much brake dust to begin with anyways.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
11-14-2022, 07:59 AM | #5 |
Rep 317
I don’t have CCB on my m3 but Porsche recommends using the 2 studs across eg in position 1&2 on how you would tighten a star pattern is the best way I can describe it. You don’t want the wheel to swing or sway in a way it can contact the rotor
11-14-2022, 08:15 AM | #6 | |
BMW addict
395
Rep 485
perfect ..that is what I was planning
11-14-2022, 04:57 PM | #7 |
Rep 956
I bought two of these and use them to remove/install wheels, so far, they work great.
https://burgertuning.com/collections...wheel-pin-tool
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
JTM09395.00 |
