12-31-2008, 12:40 PM | #1 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
standard audio at high volume?
i am usually listening to USB drive or Ipod
when i turn it up very high sometimes in a song the voulme starts going down like the amp is trying to stop the signal from distorting and lowering the gain is this a common thing? or is there something wrong with my system? this is the standard audio system without any upgrades all stock |
12-31-2008, 02:43 PM | #2 |
Rep 2,339
Haven't experienced that yet and I've got it up pretty loud a few times. You know one thing that irritates me about the OEM audio system is that there is no volume display. Nothing that tells you how far up the volume control range you are. It would be nice to know especially once I get my aftermarket equipment installed to set gains and allow for headroom on low recordings.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
12-31-2008, 04:42 PM | #3 | |
Rep 13,018
01-04-2009, 07:42 AM | #4 |
Rep 6,845
i thought so
but the sound is not distorted when it does that i wonder if fitting an aftermarket amp would fix that? i know its easier to do hat with the base sound system |
01-04-2009, 10:31 AM | #5 |
Rep 13,018
01-04-2009, 10:32 AM | #6 |
Rep 6,845
no i mean sometimes it does it when the volume is not turned up all the way
say around 70-75% and it brings the volume down significantly, say around 45-50% i wonder if that is a function of the amp or the head unit? |
01-04-2009, 11:11 AM | #7 | |
Rep 13,018
You could try first to set your speed volume compensation to the minimum and see if that affects somehow your volume issue. |
01-04-2009, 01:24 PM | #8 |
Rep 6,845
i did that
is the minimum with one segment lit? do you know which wire is the speed sensing one? i could try setting it to the max and seeing if its the same kind of level compensation |
01-04-2009, 04:42 PM | #9 |
Rep 13,018
