11-22-2022, 12:21 AM | #1 |
Rep 14
Help drive cycle
I need help passing smog, everything works but the OBD2 reads:
O2 sensor incomplete CAT incomplete Secondary air system incomplete been trying different things recommended here and there, mind you I also have not tags nor plate for the car unless I pass smog. Any suggestion or ideas please let me know. I drive a 2008 BMW E93. |
11-22-2022, 02:48 AM | #2 |
Rep 21
NiBe463.50 |
11-22-2022, 05:12 AM | #3 |
Rep 370
If there are no errors in DME and no problems with the car (such as stuck thermostat - aka the car will not stay in operation temperature) then go for a long drive and everything will be fine. Btw you can check status of these tests on your own with OBD2 reader such as CarScanner (emission tests section).
11-23-2022, 11:37 AM | #4 |
Rep 175
Get on the freeway late at night and park yourself in the slow lane at 60mph for a good 20-30 minutes. Get off the freeway and then do the same thing again going back home. Keep it under 60mph the entire drive. Works for me every time.
