12-03-2022, 10:06 PM | #1 |
Rep 2,971
Stealth Hitch + S8SL Car coding needed?
Hey guys
Soon going to be towing roughly 5500lbs (track car + others) - and have narrowed my search to stealth hitch. My new to me 18' does have "S8SL" option. Can someone tell me if the following is all that is needed: -Stealth Hitch + Active harness + coding. Also is this the best option to date? Thanks in advance Last edited by Exclusivs; 12-04-2022 at 10:43 AM.. |
12-04-2022, 01:17 AM | #2 |
Rep 243
I went the stealth hitch and tekonsha route. Couldn't be happier. I don't do a lot of towing so a little beeping while in reverse doesn't bother me.
12-04-2022, 08:31 AM | #3 | |
Rep 429
12-04-2022, 08:41 AM | #4 | |
Rep 429
Check here: www.mdecoder.com I have a 2018 x5m with stealth hitch and Tekonsha wifi controler working perfectly Last edited by gan23; 12-04-2022 at 08:53 AM.. |
Exclusivs543.00 |
12-04-2022, 10:34 AM | #5 | |
Rep 2,971
So Stealth +active harness and coding>? |
12-04-2022, 07:51 PM | #6 | |
Rep 429
It's ok to use a coder also but be aware that if you update the iLevel of the car, you might need his services again. |
Exclusivs543.00 |
12-04-2022, 09:11 PM | #7 | ||
Rep 2,971
Even with S8SL no module right? My trunk |
