BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      01-02-2009, 04:46 PM   #1
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
Question regarding alignment and also tire pressure.
Well since I dropped my car on eibachs i was waiting for the 2 weeks to go by so that I could get an alignment done. Well 3 weeks went by and I finally got my alignment done, but I gotta be honest, I kinda liked how the car felt with the extra negative camber. So my question is can i go to my guy or dealer and have them dial in more negative camber or would it feel wrong without doing anything to the toe?
If anyone has done it, can you suggest what setting I should have my negative camber at and if i should leave the toe alone, thank you.
One more thing. I have my air pressure on the rccommended 33 and 35, but since its winter and cold as fuk, i was thinking id be better off going with mayb 40 in the back and 38 in the front or even 38 back and 36 front. Does this sound better? My front tires just seem low and mushy.
      01-04-2009, 07:42 PM   #2
eagletangogreen
Got Track!!!!!!
eagletangogreen's Avatar
Drives: 08 M3 coupe
My BMW dealer set my camber an additional .3 neg all around as per my request.
      01-26-2009, 01:22 PM   #3
Schnorbitz
Schnorbitz's Avatar
Scotland
9
Drives: 318d
Hey guys, been lurking here for a while, i'm an M3 owner from Scotland.
eagletangogreen - how does the dealer adjust the rear camber? I've been under my car but can't figure out where the adjustment would be made, is it possible to adjust the toe too?
Great forum, best in the world no doubt!
      01-26-2009, 03:40 PM   #4
gthirtyfizle
191
Drives: E92 M3 AW
both camber and toe can be adjusted
      01-26-2009, 04:02 PM   #5
Schnorbitz
Schnorbitz's Avatar
Scotland
9
Drives: 318d
Thanks, how do they physically do it though? Is there adjustment screws etc or is it a shimming job?
      01-26-2009, 04:09 PM   #6
gthirtyfizle
191
Drives: E92 M3 AW
Not sure, but once u get under there its pretty simple. The back is like any other car I think. The toe is just a screw and the camber not sure. The front is weird tho, camber is adjust from the engine bay, not from underneath like every other car.
      01-26-2009, 04:12 PM   #7
JJM335
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
On the tire pressure, I leave mine stock in the winter. Those pressures add a a bit of understeer which (to me), is a good thing as cold tires can be unpredictable. In the summer months I switch them around...2 - 3 psi more in the rear that up front for the street.
      01-27-2009, 04:01 PM   #8
Schnorbitz
Schnorbitz's Avatar
Scotland
9
Drives: 318d
I think at the front you can get a small amount of adjustment on the camber by slackening the strut locating bolts on the turret in the engine bay and pulling the strut to use up some of the clearance between the bolts and the holes.
Still not sure how any adjustment is done at the back on toe or camber, there appears to be no obvious place to adjust it on any of the suspension diagrams in all the BMW technical publications, hence the reason I suspect it involves shimming.
Anyone got any ideas?
      01-29-2009, 12:48 PM   #9
elm3
///M Fan
elm3's Avatar
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
2017 BMW / X5M  [9.00]
2009 E92 M3  [10.00]
2004 Yamaha R1  [10.00]
Anybody knows where the camber adjustments are on the car (front and rear)?
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
      02-02-2009, 08:16 PM   #10
Schnorbitz
Schnorbitz's Avatar
Scotland
9
Drives: 318d
http://www.bmwmotorsports.org/BMW_docs/x5align.pdf
Found this, too old to cover the E9x but I don't think it's too different to the E46.
m3post
