12-13-2022, 11:26 PM | #1 |
Rep 13
Any thoughts on UOA? - 18' M4
18' M4 @ 54K miles.
Maintained at 5K OCI since 15K miles. I'd appreciate any thoughts on the UOA attached. Anything concerning? Not sure if it helps, but this was the oil change for the first time I lost 0.5 liters b/w the intervals. No oil leaks or low oil warnings. Last edited by saikumarmeka; 12-13-2022 at 11:32 PM.. |
12-13-2022, 11:36 PM | #2 | |
Rep 3,729
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
12-14-2022, 09:22 PM | #3 | |
Rep 13
If so, how is it typically recommended to run oil for 10K OCI, given LM 5w40 is LL01 approved? Just wondering, |
12-14-2022, 09:54 PM | #4 | |
Rep 3,729
Here is a UOA of my wife’s N55 which is run exclusively on full E85 using Motul Xcess Gen 2. Her results are much better and the oil stayed within spec throughout 5000 miles even with E85. Keep in mind her car runs at operating temperatures around 250f so it runs much hotter than our cars (226f). This is actually good for her since the hot oil will burn off the excess water from the oil. Even with this higher operating temperature, the used oil remained very strong.
N55Msport187.00 saikumarmeka0.00 |
12-15-2022, 07:38 AM | #5 |
Rep 132
I have done 8 UOA’s on my M3, you can reference mine at around 52,00 miles. I too see the viscosity being the standout issue . Fwiw… I switched to Motul as noted and my overall viscosity held up much better then when I ran LM 5W40 (Molygen). In general a lot less shearing.
My N55 in my wife’s 335i has had Motul 5W40 Xcess Gen 2 as well and the latest report on her engine had the comment of “fifty shades of excellence “. (I’m not making that up). So, for my 2C….. try Motul and see what a couple of 5000 mile runs show. I hope that helps. https://share.icloud.com/photos/0f42...taz2_vk3Jg3QrQ |
hellokitty2899.50 saikumarmeka0.00 |
12-18-2022, 07:14 AM | #6 |
Rep 210
Castrol Euro Only. I put them in all the M’s I have worked on. No problems and great oil. It’s as a matter of fact the Twin Power Turbo Oil that BMW slaps their label on
