12-31-2022, 02:12 PM | #1 |
Rep 1,573
Things to look out for in 100k+ mileage E92 M3
looking to purchase a super cheap toy car to drive to the grocery store on occasions...stumbled across a 2008 E92 M3 with 110k miles thats priced in my budget. What are some things i should be weary about other than the usual (brakes, tires,etc)....what are some common failures at that mileage? transmission? its a 6MT
2015i Cadillac Escalade ESV
12-31-2022, 03:12 PM | #2 |
Rep 2,072
check out the sticky at the top, but it's rod bearings, throttle actuators and engine mounts. the rest is standard 100k mile car stuff.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
Robocop30512.00 |
01-01-2023, 11:49 AM | #4 |
Rep 1,573
thank you, this is good. rod bearings seems like the big ticket. engine mounts seem normal to me, not sure how easy/difficult throttle actuators are (from a mechanic perspective, not DIY)
01-01-2023, 01:39 PM | #6 |
Rep 2,072
if you're used to wrenching, replacing the actuators is pretty straightforward. pull the plenum and they're right there. some people are scared of pulling the plenum but it's cake, you just need a 6mm socket and long extensions.
01-01-2023, 01:41 PM | #7 |
Rep 2,072
why the threadjack? the soft touch can't be repaired really. you can either peel it off fully and live with what's underneath or replace the parts. i think the newer versions aren't as susceptible to peeling.
01-01-2023, 06:03 PM | #9 |
Rep 4,180
Only rod bearings. Throttle actuator preventive replacement is overrated and its cheap to replace these days. TA failure won't cause engine damage, so they're not urgent. Do them when they start to give errors.
Other items are wear and tear related. Engine mounts yes. Check for oil leaks at the transmission and engine valve covers. Other than that, there's really not much to worry about. |
Robocop30512.00 Ali-E90381.50 |
01-01-2023, 10:23 PM | #10 | |
Rep 2,072
01-02-2023, 02:12 AM | #12 |
Rep 1,059
Rod bearings - These will destroy the engine when they go. Replacement bearings are available that claim to cure the issue such as BE Bearings.
Throttle actuators - I recommend doing proactively, if they are OEM and have more than 40K. While it wont damage the engine when it fails, it will leave you in limp mode. That would suck quite a bit if you were not close to home. There are 3rd party lifetime warranty replacements available that supposedly wont fail. Fuel injectors- Over the last few years there has been a large increase in fuel injector failures taking out engines. I wouldn't even hesitate to have them replaced if they haven't already been done at this point. VANOS Covers- Also a newer failure that is starting to show itself with age. The plastic covers on the end of the vanos units are getting brittle and cracking, and eventually break. Once they do they can clog the oil pickup tube blowing the engine. Can be permanently fixed with metal replacements. For a car with 110K, I would plan on tackling everything above unless its already been done. The rest of the car is pretty solid. In fact, it's been the most reliable car I've ever owned. All of the major issues can be addressed. One thing to keep in mind, the S65 engine is not cheap. A new one was around ~$25K last I heard. The cost of fixing the issues above permanently is easily justifiable. Last edited by drwankel; 01-02-2023 at 02:26 AM.. |
01-02-2023, 06:49 AM | #13 |
Friends don't let friends ESS
3223
Rep 887
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
I bought an e90 with 98k miles and did a 100k refresh in ‘22.
Agree: rod bearings and throttle actuators if not addressed, and engine mounts if worn (you can inspect them with a fiber optic scope). Of the three on this list, I only had to do the motor mounts. This has been my other list: Belts Pulleys Water pump Coolant hoses Thermostat Alternator AC compressor (failed) Plugs Injectors Fuel tank breather valve Valve cover gaskets (do the Vanos covers while you’re in there) Manual transmission fluid and transmission mounts Rear differential fluid Rear differential axle seals Brake fluid flush Replaced every control arm, front and rear I did most of this myself over 6 months, most of it preventative or when I was swapping out the ESS for the Harrop supercharger. I drive my now 115k mile m3 with total confidence, including long remote car trips. Enjoy it! |
