01-04-2023, 08:47 PM | #1 |
Rep 37
I Need some advice
2015 M3 47k price 48miles
Mineral Grey less than desirable packages 2017 M3 52k Price 36k miles All packages I desire except competition package. If I buy the 2015 for 48k the extra money will be used on crankhub and upgrading charge pipes and J pipe. If I buy the 2017 for 52k then I’d wait a few months to get the crank hub and everything else done. In the back of my mind I have this fear of buying the 2017 and with my luck spinning the crank hub in a few months. Is the spun crank hub as common as the forums would like us to believe or is it much less but blown out of proportion by manufacturers and shops? |
01-04-2023, 09:24 PM | #2 |
Rep 31
Just from your comment about the less desirable packages on the '15 I would say go for the 2017.
Lots of F8X cars still going strong with more miles and no updated crank hub but I understand the piece of mind. |
01-04-2023, 10:06 PM | #3 |
Rep 5,188
Completely blown out of proportion by vendors and shops… You're at stock power.
At that mileage if the stock hub was gonna spin it would have long ago. Get your baby, the newer one you want. If you put a crank bolt capture plate over your stock hub that'll buy you enough protection for Stage 1 or 2, and even E30 fuel. To do full E85 and more upgrades then you'd want a hub fix and the CBC over top.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
01-05-2023, 07:37 AM | #4 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
Get the 2017...it's worth the extra money (although I'd negotiate that) and the telecomm features still work. My 2015 can't be upgraded to 4G communications for a reasonable sum, and there are other worthwhile feature upgrades in the 2017 model year.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
spidy512502.00 theweebabySeamus382.00 |
01-05-2023, 09:19 AM | #5 |
Rep 276
Get the 2017. You can always get the most of the desired comp options added (seats might be tough to come by) but black badges, grilles, fender inserts can be added.
01-05-2023, 09:56 AM | #6 |
Rep 879
Newer car and lower miles is always the best choice if it fits your budget.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
01-05-2023, 11:49 AM | #7 |
Rep 14,141
Drives: G82 M4C X-Drive
I've had 2 F80's, both tracked, both driven HARD on the track. I've never spun a crank hub. Granted, I kept the power stock and I don't do launches from a dig often. Only in autocross did I do hard launches.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-05-2023, 02:02 PM | #8 |
Rep 201
Are you planning on tuning/adding boost? If not you don't need to do any of that. The crank hub is fine for stock power. Very overblown issue that affects like 1% of cars. Likewise the stock charge pipes and j pipe are completely adequate for stock power.
I say this as a 5 year owner of a stock 2015. |
01-05-2023, 02:14 PM | #9 |
Rep 1,081
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
If you want Comp, don't buy a car without it. Wait for a 2017 & 2018 to come around that has the options you want. Plus the longer you wait the better prices will be.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
01-05-2023, 02:17 PM | #10 | |
Rep 37
TopJimmy5512.00 |
01-05-2023, 03:04 PM | #11 |
Racecar Driver
1312
Rep 1,989
Drives: BMW M4
That is a very important package IMO. Once you live with a HUD, it's hard to go back.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
