02-19-2023, 02:01 AM | #1 |
Rep 397
FS: Dinan strut bar - New
Bought these strut bars brand new but turns out it does not work with Haimus CF plenum. Comes with hardware and instructions $480 shipped Last edited by siulung2005; 03-06-2023 at 12:04 AM.. |
02-19-2023, 01:40 PM | #3 |
Rep 397
The inner mounting part is touching the the plenum. Not sure why. Maybe I have a brand new engine mount so it sits higher?
02-19-2023, 02:55 PM | #4 |
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
Not sure why but the Passenger side Brace sits lower than the driver side. I have Eventuri Plenum and had to shimed the brace up by about 3/8" to have enough clearance. The brace appeared to clear aftermarket Plenum the engine expanded when hot. I have seen several members here damaged the corner of the Carbon Plenum because of this.
02-20-2023, 10:41 AM | #5 |
Rep 232
mine initally looked like it wasnt going to fit but then i saw that the back of my haimus manifold wasnt all the way seated. seated it and it was perfect. it for sure is a tight squeeze but once its seated it was fine. no shimming needed on my end. i made sure to lube the couplers where the manifold connects to the ITB real good and it slid right in.
Ohlins | Swift | Vorshlag | Epic | Corsa | Evolve | Eventuri | Haimus Racing | BW | TMS | J-Fiber | Hotchkis | Do88 | RTD | BBS | Dinan | Ground Control |
02-20-2023, 10:51 AM | #6 |
Rep 232
funny enough, this got me curious, i went to look at mine just now and i too now have some slight marking that wasnt there before. going to have to investigate. i may too have to shim afterall.
02-21-2023, 02:48 PM | #7 |
Rep 397
02-22-2023, 07:41 AM | #8 |
Rep 456
Drives: 2008 BMW e92 M3
Firm on price ?
02-22-2023, 11:51 AM | #9 |
Rep 1,002
You will need about 3/8" clearance when the engine is cold. Anything less than that will have be problem when the engine is hot.
