02-20-2023, 06:55 PM | #1 |
Rep 64
Intermittent Bank 2 Misfire and Rough Idle
SOLVED. Summary at the bottom of this post so you don't have to read the whole thread if you don't want to:
This is kind of a long post, but I've been having a weird misfire as of late and wanted to see if anyone has any idea whats going on with my car. Car: 2008 BMW M3 6MT 94k miles RBs done at 77k TAs done at 80k Spark plugs done at 91k RKP Street Xpipe that definitely leaks a bit The first time it happened I was letting my car warm up after work, sittiing on my phone while it idled for a little after starting it. I noticed the car starts to shake and the idle becomes rough. I get limp mode and a SES light. I immediately turn the car off and scan for codes and get the following: 2729 DME: Oxygen Sensor, coast-mode diagnosis before cat, bank 2. 27B1 DME: Secondary Air system flow rate, bank 2 2B39 DME: Misfire with cutoff, cyl 5. 2B3A DME: Misfire with cutoff, cyl 6. 2B3B DME: Misfire with cutoff, cyl 7. 2B3C DME: Misfire with cutoff, cyl 8. 2B41 DME: Misfire with cutout, several cylinders I clear the codes and restart the car, because the O2 sensor codes have also been randomly coming and going and I just replaced the bank 2 precat o2 sensor 3 weeks prior so I assumed those were stored codes. After I restart the car it runs totally normal. I drive it home with no issue. I go 12 days with no issues until i get the same rough idle, shaking, and limp mode at a red light, pretty soon after leaving work (car was not fully warm). As soon as I get limp mode I cut the ignition off, wait 15 seconds, and restart the car... and its totally normal again. I scan the car for stored codes after I reach my destination and get the following: 275E DME: Oxygen sensor limit position error bank 2 2B46 DME: Misfire impairing exhaust emission cyl 5. 2B47 DME: Misfire impairing exhaust emission cyl 6. 2B48 DME: Misfire impairing exhaust emission cyl 7. 2B49 DME: Misfire impairing exhaust emission cyl 8. 2B4E DME: Misfire impairing exhaust emission, several cylinders. I end up having to go to a wedding the following day, so the car sits for 2 days before I work on it. I get it up on the lift and check all the o2 sensors are plugged in and none of the wires are damaged. They look fine, so I try starting the car. It doesnt start well and immediately starts misfiring. The codes above remain the same. I swap the bank 1 and 2 O2 sensors to see if the misfire changes sides. I restart the car and its definitely still misfiring and idling poorly. So I clear codes to see if the misfire changed sides and the car wont give me another SES. It idles poorly but the light won't come on so the codes weren't posting. I call it a night because at this point it was late and the car is loud and I didn't want to bother neighbors. The next day I start the car and its totally normal. Can't get it to misfire. I drive it for 20mins, do a few pulls to redline, let it idle for 5 mins and nothing. No codes, starts fine, idles normal. Anyone have any idea whats going on? RESOLUTION: I ended up replacing: -All 4 O2 sensors (3 times) -Secondary air pump, valves, hoses -Coolant temp sensor -Valve covers, valve cover gasket, spark plug tubes -Spark plugs -Got a unmodified OEM X Pipe -All exhaust gasksets and hardware And STILL had the same problems. Ended up stripping the O2 sensor plug harness to check for wire damage and re-sheathing the wires. Problem Solved. Weird. Last edited by Contra; 12-05-2023 at 09:35 AM.. |
02-21-2023, 05:19 AM | #2 |
mTekMods
2161
Rep 2,912
these cars are fairly sensitive to a leak from the header to middle exhaust, if you know theres a problem there you should address that first. the o2 sensor has reached the limit of its trim adjustment.
DrFerry6731.50 |
02-21-2023, 08:17 AM | #4 | |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
02-21-2023, 08:18 AM | #5 | |
Rep 64
Pics attached. I’ve been trying to find an OEM X-pipe near me to remedy this, but I’m honestly leaning towards just having the X pipe welded to the cats and calling it a day. Was kind of hopeful I could go back to OEM then sell my cats and the RKP pipes to recoup some money. |
02-21-2023, 08:21 AM | #6 |
Rep 64
I bought and installed 2 new OEM gaskets 12k miles ago. I'd be a little surprised if they failed already, but I'll check them out the next time I get under the car.
02-21-2023, 08:23 AM | #7 | |
Rep 64
I have had the fluctuating idle after filling up for a little while, but its never been severe. Just a slightly surging idle. No close gas cap warning. Also I'm only getting bank 2 misfires. I figured if this issue stemmed from the breather valve then it would be both banks misfiring, right? |
DrFerry6731.50 |
03-14-2023, 10:49 AM | #8 |
Rep 64
3 week update: Car still hasn't misfired since. Still haven't changed anything other than switching the bank 1 and bank 2 O2 sensors around. Really strange.
I've been putting off changing the fuel breather valve just to see if the missfire comes back, but it hasn't. Car needs an oil change this weekend, so I'll probably install it then. |
03-16-2023, 04:10 PM | #9 |
Rep 79
I had misfire on bank 2 last year. I had similar error codes. My misfires were actually due to engine oil overfill which messed up crank case pressure. So just in case you have added some oil or changed oil, you could check/estimate the oil level in your car.
2003 E39 540i M Sport 6 speed
2009 E90 328i Sport 6 Speed 2013 E92 M3 Base 6 speed 2013 E92 M3 Comp 6 speed |
03-17-2023, 09:30 AM | #10 | |
Rep 64
Doesn't the car tell you its overfilled if you add too much? Also, the oil level is already back down to the middle mark so I couldn't have put that much more than the middle. I normally have to add ~1 qt per 7,000 miles or so when I change the oil. |
aggieshan38.00 |
03-21-2023, 12:34 AM | #11 | |
Rep 79
Contra58.00 |
03-21-2023, 03:40 PM | #12 |
Rep 64
This weekend I changed the oil and tackled the fuel tank breather valve. Got a new OEM one installed and noticed this hose clamp for the idle control unit piping had broken (circled in red).
This could be the culprit, but also I checked my pics from 2020 when I did my throttle actuators and it was broken even in those photos. Might cut this one and replace with a normal hose clamp so I can slip it on without having to removed the whole tubing “T” section. Last edited by Contra; 03-21-2023 at 03:45 PM.. |
DrFerry6731.50 |
03-22-2023, 10:07 AM | #14 | |
Rep 64
Not sure when I'll get around to replacing the clamp. It'll become a priority if the misfires return. I'll definitely keep this thread updated if something changes. |
03-22-2023, 01:25 PM | #15 | |
Rep 362
Drives: E53 X5, E83 X3, E93 M3
You could've disturbed the wiring enough by switching sides that now it's functioning, in addition to perhaps getting a better clamp on the exhaust header there.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
07-03-2023, 09:27 AM | #16 |
Rep 64
Update: The misfire came back......
Since my previous post, I found an OEM X-pipe off a 26k mile car for sale locally, bought it, and installed all new OEM gaskets, new header connection bolts, and exhaust supports. I did this to solve my exhaust leaks and hopefully stop killing O2 sensors so frequently. A month or so after the OEM x pipe install, the misfire returned with the exact same symptoms and codes one morning while warming the car up. Turned the car off, cleared codes, and restarted it. Still misfiring. So I had it towed to a shop to investigate since I was going to be out of town for work for 2 weeks the following day. The shop was less than helpful and didn't really seem to know the cause either. I had them replace the busted clamp on the idle control valve piping (photo in my previous post) and they said the misfire went away. Picked the car up when I returned from my work trip and it ran great for about a week. Then the check engine light came on again during a cold start one morning, and I felt the car start to shudder and hunt for idle. I gave it a little bit of gas and it smoothed out. Scanned for codes and got 2729 and 27B1 again. Ordered a new O2 sensor (even though the one in the car is less than 5k miles old) and will be installing that when it arrives. |
07-03-2023, 06:38 PM | #18 |
Rep 64
Like drive around with the throttle bodies exposed? Would that be just to rule out issues with the plenum? I also got 8 new throttle body couplers (the rubber things that hold the plenum onto the throttle body) while the shop had the car since mine were pretty tired and sad looking.
07-03-2023, 07:19 PM | #19 | |
Rep 4,180
DrFerry6731.50 |
07-05-2023, 04:42 PM | #20 | |
Rep 362
Taking the plenum off has little to no effect on vacuum. This pressure would technically be atmospheric in the plenum. If we're concerned with misfire, a good way to verify this is to look at the spark duration and combustion quality panel in ISTA. Need to rule out the ignition. But since it's on bank 2 cylinders only, means it's something on that side. What are the o2 readings in closed loop for bank 2? The other fault code makes me think there is a suspect exhaust leak on bank 2 like was mentioned before. Curious...
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
07-05-2023, 05:33 PM | #21 | |
Rep 4,180
And for the record the engine runs fine in alpha-n mode without the plenum. I would not recommend doing it for extended periods as there is no filter but a couple minutes just to localize a possible air leak is fine. |
DrFerry6731.50 |
07-05-2023, 07:31 PM | #22 |
Rep 362
Was it a supercharged engine? Hmmm...I have heard of part of the interior tube part cracking. Interesting...
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
